AC(Air condition) blowers not blowing cool air - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2008, 01:48 PM   #1 (permalink)
View desidreams's Photo Gallery
This is my first posting.Thanks in advance for Answering my Question.
I have 1998 toyota camry.
Issue:AC cooling is not comming from the dash board vents(Passenger seat).My driver seat Vent blows cool air and i am happy.My passenger seat fan is working but the Cool air is not comming.Please suggest.
desidreams is offline   Reply With Quote
Old 05-04-2008, 03:07 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
There is only 1 fan if Im not mistaken. Some of the your vent tubing may be blocked going to the passenger side or maybe some has come loose and is not allowing air to get all the way to the vent. Like its leaking out somewhere else.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 05-04-2008, 06:48 PM   #3 (permalink)
Oh is something blocking to send cool air?how i can i check that what is blocking?
Old 05-09-2008, 08:58 PM   #4 (permalink)
View MrCamryWagon's Photo Gallery
Interesting. Something similar has just happened with our '95 camry.
It stopped delivering air altogether from the center vents, and this after a noise like something was loose at the highest (fastest) fan setting.
MrCamryWagon is offline   Reply With Quote
Old 09-01-2008, 11:43 PM   #5 (permalink)
View 626camry's Photo Gallery
i had the same problem. finally fixed it by putting in freon. now the ac is cooler then ever!
626camry is offline   Reply With Quote
Old 09-02-2008, 03:43 PM   #6 (permalink)
Search the Gen3 section for 'center vents'..you will find my thread about what was causing it and how to fix it.
Old 09-02-2008, 06:31 PM   #7 (permalink)
View proftomda's Photo Gallery
Verify that your passenger ducting is OK by turning on the heat and ensuring that heat comes out evenly on the drivers and passengers side. If heat comes out evenly both sides, you may have a weak AC system. If heat is weak on the passenger side like when the AC is on, you probablly have a ducting issue. Its always ggod to get a check up of your AC system to make sure your pressures are OK. A weak AC system and ducting length differences may bias towards the driver or passenger.
proftomda is offline   Reply With Quote
Old 09-02-2008, 07:50 PM   #8 (permalink)
just a nobody
There maybe a sight gas in the engine compartment for you to check you refrigerant; if you see bubbles in the sight glass when it is running, you are low, unless it is full or completely empty.
Low refrigerant would cause something like you had described.
N.E.O.
