Factory speaker grills?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2008, 12:39 PM   #1 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation Factory speaker grills??
Is there any way of replacing factory speaker grills for a GEN3 Camry without cutting anything? I think there is a way for the 6x9's but I'm not too sure about the 6 1/2's...
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 05-06-2008, 10:10 AM   #2 (permalink)
JayMax03's Avatar
ok besides this question why wouldn't you get a tranny flush in a Toyota Camry?
Old 05-11-2008, 05:55 AM   #3 (permalink)
JayMax03's Avatar
Anything Would Be Nice
Old 05-11-2008, 09:38 AM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
1) What will you replace the door grilles with? Another set factory grilles or aftermarket ones? Aftermarket grilles will require custom fabrication(cutting, and fiberglass) to mount them in the front doors. As for the 6x9s, aftermarket griiles may attract the attention of theives. However, if you remove the rear deck panel, you can remove the factory 6x9 grilles and install aftermarket ones.
2) If you trans still shifts smoothly, why spend the money on a flush? Just drain and refill with new fluid. If your trans is having problems shifting or the fluid hasn't been changed in a long while then it's probably a good idea. Other than that, save your money.
uibalnme is offline   Reply With Quote
