1996 Camry - How do you replace the brake light bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2008, 12:27 PM   #1 (permalink)
View camry1996's Photo Gallery
Both of my brake lights went out and im at work right now. Is there anyway to replace the brake light bulbs without tools?
camry1996 is offline   Reply With Quote
Old 05-06-2008, 12:31 PM   #2 (permalink)
View Bear95's Photo Gallery
Did the third light go out as well?
Bear95
Bear95 is offline   Reply With Quote
Old 05-06-2008, 12:33 PM   #3 (permalink)
Bear95
yup Well first the passanger side went out, then the 3rd brake light went out, then today i notice the driver side went out also.
Old 05-06-2008, 12:46 PM   #4 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
If you need to change the bulbs in the tail lights, open the trunk. Opposite the tail lights inside the trunk there are fabric covers covering the trunk wall. Carefully remove the christmas tree clips that hold the fabric covers in place. Peel back the fabric and you'll see some bolts that come through the wall with nuts on them. Remove the nuts. That will free up the tail light assembly. Gently work the tail light assembly out.
The bolts that I metioned free up the part of the assembly that's facing to the rear. Around the corner of the car, the side of the light has pin of sorts that goes into a socket instead of a bolt that goes thru to the trunk. So you have to kind of gently work that loose. Once you've got it away from the car, then you can remove the light socket that plugs into the assembly.
Reinstalling is self explanatory after you've taken it off.
Hope that helps.
eddie926 is offline   Reply With Quote
Old 05-06-2008, 12:50 PM   #5 (permalink)
i guess have to do this when i get home
Old 05-06-2008, 12:54 PM   #6 (permalink)
'95 Camry V6 XLE
I just changed my rear passenger side bulb. It took 5 minutes. Not hard. You'll need a wrench or pliers to loosen the nuts inside the trunk that hold the assembly in, but that's the only tool you'll need. If you have the new bulbs in hand it's a very quick change.
Old 05-06-2008, 12:54 PM   #7 (permalink)
Hope that helps.
Yep, that is a good explantion....Just be careful when you are taking out the light assembly so you don't scratch your paint or break the lens. The OP asked about tool use and yes you will need something to remove the nuts that hold the ass. in place.
Bear95
Old 10-27-2008, 11:24 AM   #8 (permalink)
View maestro123's Photo Gallery
thanks
thanks for the write up on this. i followed the instructions to the T, and it was very easy. Pretty easy do-it-yourself and cheap. Parts are only 4 or 5 bucks for the 2 brake light bulbs.
96 Camry LE (245,XXX mi)
maestro123 is offline   Reply With Quote
Old 10-27-2008, 08:28 PM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
That's strange. The only thing I needed to do was remove 2 screws on the side of the light to remove my left tail light and replace the bulb yesterday. Didnt need to pull up carpet or remove bolts/nuts.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 10-27-2008, 08:31 PM   #10 (permalink)
Do not buy from
View Zviator's Photo Gallery
Screwing off is easy, removing the tailight assemble is the tricky part ... When I first did it, I had a hard time deciding wheather to push or to pull, lol.
Zviator is offline   Reply With Quote
Old 11-28-2008, 04:44 PM   #11 (permalink)
View Stevie_Z's Photo Gallery
Also
My Camry has the same assembly. No need to pull back the carpet or remove the nuts on mine either. Step 1- remove the 2 screws on the tail light assembly that are toward the middle of the car. This will free up the inside- toward the middle of the car- part of the assembly.
Part 2---- very very very important---- after where the assembly curves around to the (driver or passenger) side of the car, there are 2 posts that fit snugly into plastic sockets and these are what's holding the tail light assembly in place. You want to gently work a screwdriver or something in and slowly and carefully pry the posts out of their retaining clips.
Once the assembly is clear, it's pretty obvious where the bulbs go.
Just FYI, for the front parking lights, it's a similar procedure. Remove the 1 screw (you need a small "star" screwdriver to remove it) and then pop out the other side.
Stevie_Z is offline   Reply With Quote
Old 04-12-2009, 11:23 AM   #12 (permalink)
tekno9000's Avatar
View tekno9000's Photo Gallery
3rd Generation
Hope that helps.
Sorry for the dumb question, but how do u remove the christmas tree clips? I already broke one.
Thanks,
Tekno 9000
1995 Camry LE 5SFE 4 Cyl.
tekno9000 is offline   Reply With Quote
Old 04-12-2009, 11:45 PM   #13 (permalink)
Gameroom cash: $105400
View dz63's Photo Gallery
There may be a better way, but I use a pair of side cutters to get in behind the plastic plug and then carefully pry it out of the hole. This method works pretty good.
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
dz63 is offline   Reply With Quote
Old 04-14-2009, 04:00 PM   #14 (permalink)
tekno9000's Avatar
Thanks, DZ. I pried open with a screwdriver using some WD40. Would like to add that after removing the two 8 mm nuts, remove a clip (White, in my car) by pressing and then pull the headlight out sideways.
Thanks all TN members.
Thanks,
Tekno 9000
Old 10-05-2010, 05:00 PM   #15 (permalink)
View mistersink's Photo Gallery
Bear95
On mine, the two side brake lights went out, but the center light in the cab did not. Both side lights went out at the same time, is this a bulb issue?
97 Toyota Avalon XLS V6
mistersink is offline   Reply With Quote
