Can I bypass my rusty load sensing proportioning valve? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2008, 07:01 PM   #1 (permalink)
View bennington28's Photo Gallery
The rear brake load sensing proportioning valve on my 94 camry wagon is leaking due to rust. A replacement is $300 and most used ones are also rusty. Can I just cut out this fancy looking part and run the Master Cylinder brake line directly to each side of the rear? I do not see any sensors, so I doubt I will throw any codes.
thoughts?
-99 z28 m6 stripper, Heads, 231 cam, Duals HP Tuners 456HP
-2006 Silverado Max Crew Cab 4x4, 6.0 LQ9 355HP , 4.10rear, magnaflow
-1993 CAMRY LE daily driver- "MAN'S BEST FRIEND"
-BANNANA SEAT BICYCLE, 1/2 HP, 30MIN. 1/4 MILE @ 6MPH
bennington28 is offline   Reply With Quote
Old 05-17-2009, 11:15 AM   #2 (permalink)
View jaswasup's Photo Gallery
Canada
Let me know what you do here as i am lookng at the potential same option
Mine is bithed and lines are leaking
Mine is broken not functionong and it has no issues other than lines leakng
My thing is if i isturb anything in that area i know i will wake OpEN other leaKS
Where do the lines that go over the tank go to ?
I need to replace that line asell polly others if they wake up and leak
However if i need to put a 3 hundo sensor -prop valve in i'll pass and route it thru a block or smething
let me know what you did to fix er up please
jaswasup is offline   Reply With Quote
Old 09-02-2009, 09:02 PM   #3 (permalink)
Tedders's Avatar
View Tedders's Photo Gallery
No, no NO do NOT bypass this Load Sensing Proportioning Valve! Bite the bullet and get one new one. According to the Toyota shop manual, it helps control cornering when braking around curves.
Tedders
Tedders is offline   Reply With Quote
Old 09-03-2009, 12:13 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The valve varies the amount of braking sent to the rear wheels.
Have you tried an aftermarket part supplier? I am not sure about the price, but my brake supplier has these things for sale, I just have not needed them yet.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 09-03-2009, 12:30 PM   #5 (permalink)
View CJCride's Photo Gallery
Canada
CJCride is offline   Reply With Quote
