Just a little thing I read. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2008, 02:38 AM   #1 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
4th Generation Just a little thing I read.
Fifth generation (XV20) (1996–2001)Fifth generation (XV20)Also calledDaihatsu Altis
Toyota VistaProduction1997–2001AssemblyTsutsumi, Japan
Georgetown, Kentucky
Altona, Victoria, AustraliaBody style(s)4 door sedan
4-door station wagon (non-US)LayoutFF layoutEngine(s)2.2 L 5S-FE I4 133 hp
3.0 L 1MZ-FE V6 194 hpTransmission(s)5-speed manual
4-speed A140E automatic
4-speed A541E automaticWheelbase105.2 in (2670 mm)Length189.8 in (4820 mm)Width70.1 in (1780 mm)Height55.4 in (1400 mm)RelatedLexus ES/Toyota Windom
Toyota Sienna
Lexus RX
Toyota Highlander
Toyota Camry Solara
Toyota Avalon
The fifth generation Camry was launched in Japan in December 1996. It continued as a sedan and station wagon (called the Camry Gracia in Japan), though the latter model was not sold in the United States. This generation was launched in the US for the 1997 model year.
In 2000, the sedan models received a mid-model upgrade to the front and rear fascias, but remained otherwise similar to the 1997 to 1999 models. The Japanese Scepter ceased to exist as the Japanese Camrys adopted the 1795 mm wide platform.
The Vista began departing from the Camry, remaining 1700 mm wide and eventually forming the basis of the growing Corolla. In addition, the Vista's sheetmetal resembled a tall, formal sedan, while the Camry became sleeker. This "split" continues today.
The Lexus ES 300 was again built from the Windom, which uses the Camry chassis.
The Camry Solara was added in coupe form in 1999, and then a convertible form in 2000. In contrast to the third generation Camry coupe, the Camry Solara was a significant styling departure from the sedan. The Solara was available in SE and SLE trims, corresponding roughly to the sedan's LE and XLE trims.
In the United States, the Camry SE was dropped and the base model was renamed the CE for the 1997 model year. Both the LE and the XLE trims were carried over from the previous generation. All trim levels were available with either the 2.2 L I4 or the 3.0 L V6 engine except the Solara SLE, which was only available with the V6. The LE-based Collector Edition was new for 2001 model year.
Power was increased slightly to 133 hp SAE (99 kW) for the 5S-FE 2.2 L I4 and 194 hp SAE (145 kW) for the 1MZ-FE V6. Manual transmissions (model: S51) were only available on the CE trim level, LE V6, and any Solara model.
For the General Export Market, the Camry was offered as 2.2 GLX and 3.0 V6 Grande.
This was the first Camry to be sold as a Daihatsu; the Daihatsu Altis was identical to the export version of the Camry.
The Camry V6 was again on Car and Driver magazine's Ten Best list for 1997.
Tuners have successfully swapped a 2JZ-GTE inline 6 cylinder engine into this generation of Camry.
A more upmarket version of Camry Gracia wagon was sold in Japan as Mark II Qualis. It had no relation to Mark II sedan besides front and rear optics, which simulated those of Mark II X100. Mark II Qualis was also available in 3.0G version, with 1MZ-FE V6 engine, not available in JDM Camrys.
[edit] Australia
In Australia, unlike the previous generation, the Camry name was also applied to the V6 variants, while the Vienta V6 range was revised as the "upmarket" models. The line-up of 4-cylinder Camry models consisted of the CSI, Conquest and CSX models (automatic transmission only); all three variants were available in sedan or wagon. The Camry V6 models consisted of CSI and Conquest, with the wagon models only available in automatic transmission. The Camry V6 Touring Series sedan model was launched in March 1999. The Vienta line up consisted of VXI and Grande sedan models and the VXI wagon. The VXI model was basically a V6-powered version of the 4-cylinder Camry CSX model.
In September 2000, the revised Camry was launched. The Vienta V6 range was discontinued due to the launch of the Avalon sedan in July 2000 and two new models were added to the Camry range: the top-of-the-range Azura V6 sedan and the Touring Series V6 wagon, both of which were available with an automatic transmission only. Towards the end of the model run, the limited edition Intrigue and Advantage sedans were launched.
-I was kinda baffled when they mention the 2jz being in a camry So I have been searching the web for this 2jzgte camry and came up empty. Any Ideas?
-samarai912
1997 Toyota Camry Le
1mz-fe turbocharged @ 7psi
all custom all the time.
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 05-07-2008, 09:59 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
...um no.
cool info
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-07-2008, 10:46 AM   #3 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
um, FAIL?
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 05-07-2008, 11:23 AM   #4 (permalink)
xet
View xet's Photo Gallery
"Fifth generation (XV20) (1996–2001)Fifth generation (XV20)"
I stopped reading after that
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 05-07-2008, 11:45 AM   #5 (permalink)
samarai912's Avatar
yeah the actual fourth generation was only released in japan supposedly. I know you guys don't like it hell I don't either but to tell you the truth it was an ugly car.
[edit] Fourth generation (V40) (1994–1998)
Fourth generation (V40)Production1994–1998AssemblyTsutsumi, JapanBody style(s)4-door sedanLayoutFF/F4Engine(s)1.8 L I4
2.0 L I4
2.2 L I4 (turbodiesel)Length4625 mm (182.1 in)Width1695 mm (66.7 in)Height1410 mm (55.5 in)–1435 mm (56.5 in)
The Camry V40 appeared in July 1994 exclusively for the Japanese market. Engines for the V40 comprised of a 1.8 litre (4S-FE type) and 2.0 litre (3S-FE type), and a 2.2 litre turbodiesel (3C-T type). At launch only the 2.0 litre model was available in all-wheel drive mode, although afterwards the 2.2 litre turbodiesel could be optioned with this system.
Toyota updated the V40 in June 1996. In the update anti-lock brakes and dual air bags became standard equipment. After 1998, the Japanese market Camry and international Camry became in-line with each other, with the Toyota Vista taking over the V30 and V40 Camry roles.
Old 05-07-2008, 12:19 PM   #6 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
I hate to say this, but the fact-checking on Wikipedia is getting awfully weak these days.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 05-07-2008, 02:28 PM   #7 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
yup... they can be helpful or mis-leading..
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 05-07-2008, 07:33 PM   #8 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
I LOATH Wikipedia. I have tried to correct false info there, but someone flagged me as a spammer or some crap like that. I used to see false sh!t all the time, but now I don't even go there.
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 05-07-2008, 09:57 PM   #9 (permalink)
The Connoisseur
CharmCityES's Avatar
LOL at this
a 5th generation camry is a 2002-2006 model....i should know as i own one...its def the 5th generation of camry sold in the U.S of A
and ive never seen a 2jz-gte in a camry....im calling total BS
The "Executive Sedan"
Old 05-08-2008, 02:15 AM   #10 (permalink)
I HAS BOOST!!!
bigbird's Avatar
well that statemnt looks liek it was added by whoever found the info...theres NO mention of preformance anywhere and then..."oh 2jz bla bla bla"...though i want a diahatsu Altis badge now.
R.I.P.
Car Domain:
Old 05-08-2008, 08:13 AM   #11 (permalink)
Noob
View gladis's Photo Gallery
Yea this is retarded. It used to follow the US style, but I guess the Camry is something else in Japan.
For our cars (Gen 3) it refers to a car called the Toyota Scepter... makes me confused.
1996 Toyota Camry LE 2.2 - 139xxx 162xxx
2000 Toyota Sienna XLE 3.0 - 82xxx 104xxx
08/08 08/11
gladis is offline   Reply With Quote
Old 05-08-2008, 12:29 PM   #12 (permalink)
xet
lol you havent scene all the scepter panels on gen 3s?
2005 G35 coupe 6mt
Old 07-02-2008, 12:15 AM   #13 (permalink)
AfterBurner_1's Avatar
View AfterBurner_1's Photo Gallery
look here: Wikipedia's listing on the Camry theyt still stuffed it up cause they did do CSi spec 5 sp Wagons right the way through, i should know i've got one!.
AfterBurner_1 is offline   Reply With Quote
Old 07-02-2008, 06:49 AM   #14 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
2JZ camry is real ... it was a drag car by Joe Signorelli ... i had edited the wiki with that, but they deleted all my work
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-02-2008, 04:14 PM   #15 (permalink)
samarai912's Avatar
Hey Venom you got link or something to that? I wanna see too!
what kind of drag was this?
