I'm no expert, but you can balance&blueprint, port&polish, maybe bore out the cylinders a bit to increase displacement, use stonger rods and pistons, which would allow more boost, play with the ECM's fuel maps or ignition timing. There is also a procedure called "kinfe edge," in which the counter weights of the crank shaft are shrpend to reduce the rotating mass, and allow the crank shaft to spin up more quickly. However, if you're going to dump all that money into a 5s, why not just get a better motor (V6 or a 3sgte swap).
