Code P0141, bank 1 sensor 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2008, 11:28 AM   #1 (permalink)
View Chiman1's Photo Gallery
3rd Generation Code P0141, bank 1 sensor 2
I replaced all three oxygen sensors on my 94 Camry V6 last November at 230K miles using the OEM Denso replacement as preventive maintenance. During the last three weeks, the engine check light came on and remained on. Oddly enough, my car came with an ODBII port. So out of curiosity, I read the code and found it out to be P0141 which relates to the O2 sensor heat circuit malfunction. I reset it twice, and the same code came back. Given that the sensor is relatively new, is it possible that the catalytic converter goes bad due to high milage. Is there a way for me to verify either the O2 or the catalytic converter is causing the checking engine light. Otherwise, my car run fine. Your input is greatly appreciated. Thanks.
Chiman1 is offline   Reply With Quote
Old 05-09-2008, 11:35 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
well teh problem with that theory is that if the cat was bad then it would throw the down stream sensor code. thatn that mights put the car in limp and throw bank 1 code. but if ya havnt had any cat codes then it running fine.
any running problems?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-12-2008, 07:52 AM   #3 (permalink)
The car runs fine. Anyone has similar experience? Any inputs?
Old 05-12-2008, 10:20 AM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
You got a defective new sensor. The heater element in the sensor is probably bad. Not common but it does happen at times with new parts.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 05-13-2008, 02:45 PM   #5 (permalink)
lolocamry29's Avatar
View lolocamry29's Photo Gallery
Had the same problem on wifes old car and took it down got a cat on it and it ran perfect. This was after everyone said O2 sensor. Do you notice any small even occationally smell?
lolocamry29 is offline   Reply With Quote
Old 05-13-2008, 04:07 PM   #6 (permalink)
ShawnM's Avatar
^ An O2 sensor heater code will not be fixed by replacing your converter.
--Shawn
03 Camry LE
67 Mustang
Old 05-14-2008, 02:05 PM   #7 (permalink)
Sounds like I have to replace another O2 sensor. Thanks for your input.
Old 05-14-2008, 10:27 PM   #8 (permalink)
Dodge Man
modain's Avatar
View modain's Photo Gallery
Check the resistance on the sensor's heater wires. You should have at least 10 ohms. Under that value you'll trip the code. The ECM expects to have a certain resistance on the circuit. If it doesn't detect enough it'll assume the heater is not working. Also, on the flip side if the resistance is too high (don't know the upper limit) the ECM will assume the heater is malfunctioning.
His - 2002 Graphite QC SLT Plus, 4.7L, NV3500, Superchips 3715, 3.92 LSD, R/T rear swaybar, no chrome, loads o'fun...
Ours - 2001 Patriot Blue Durango SLT, 4.7L, 45RFE, Fastman 68mm TB, Superchips 3715, 3.55 Open (for now)
Hers - 1997 Green Avalon XL (it's dead...)
modain is offline   Reply With Quote
