Compression Testing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2008, 12:29 PM   #1 (permalink)
View TMetalMan's Photo Gallery
Compression Testing
Hey Guys,
I'm gonna do a compression test on my '97 5SFE in a couple hours, but there's something I am not sure about: is it necessary to pull the fuse for the fuel injectors? The Toyota FSM ("Engine Mechanical I4" section) does not state anything about the fuel injectors needing to be turned off, but a little searching around on the web for general compression testing typically says to disable the fuel injectors. My question is: can I leave the fuel injectors in their normal operational state while doing a cylinder compression test?
TMetalMan is offline   Reply With Quote
Old 05-09-2008, 03:43 PM   #2 (permalink)
I just did the test, with the fuel injection system intact. I completely removed the spark plugs wires, and removed the spark plug for the particular cylinder I was testing.
The results are good: #1 and #2 are at about 155psi, and #3 and #4 are at about 170psi. I have an oil leak where I lose about 1qt. of oil every oil change (3000 miles), so this compression test tells me the piston rings and cylinder walls are fine, which I think means that I am not burning oil. Is that correct?
Old 05-09-2008, 04:03 PM   #3 (permalink)
Tech In Training
View Gun5's Photo Gallery
my car (GFs) definitly speced out at 170-170-180-180 and smokes for a sec on startup so Ill assume valve seals for her
2000 Camaro Z28 - Full Bolt ons, Heads/Cam
1994 Firebird Formula - Full Bolt ons, Heads/Cam *Parted Out*
Coming Soon 1995 Camry LE 165k
Gun5 is offline   Reply With Quote
Old 05-09-2008, 04:33 PM   #4 (permalink)
View kegunder's Photo Gallery
Be a little careful about causing a big backfire if you do a lot of compression testing while the fuel system is enabled.
Your compressions seems both low and too much diffence between min and max. Be sure that you are turning the engine for long enough to see 3 or 4 compression strokes. Also, try the test when the engine is warm (even though its a pain in the ass.)
kegunder is offline   Reply With Quote
Old 05-09-2008, 05:43 PM   #5 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Just pull the 15amp EFI fuse. Should disable fuel and spark.
Located in the engine compartment fuse block.
Pull all plugs out and wide open throttle, 4 crank rotations on all testing
Nad1370 is offline   Reply With Quote
