Originally Posted by Mike Gerber
"but yeah, now i have to get the entire wiring changed.. this is what happens when you hardly use the e-break."
Yes, the cable rusts inside it's sheath when they are not used regularly and then it is applied. If you have a little patience you might be able to get the old cable working again by liberally applying penetrating oil to the cable at it's highest point (probably inside the car by the foot operated section of the e-brake) and working the cable on and off repeatly. Also apply penetrating oil to the wheel side of the cable and continue to work it. Don't do this unless you saw what the mechanic did to free up the stuck brake at the rear wheel and feel you are capable of freeing it up again yourself, if it sticks on again. This might save you a few dollars.
Mike
Mike, that's a good idea, and it'd probably take a day to do.. i think all the mechanic did was physically try to turn the wheel and tug on the cable at the same time.. and it pretty much freed it up.
i'll take a look at it the next time i get a day off work
thanks for the suggestion.
