Vibration around 2K rpm range?
Would appreciate advice on the following(96 Camry 4cyl, 153K miles):
Recently had maintenance performed...timing belt changed, water pump replaced, oil pump seal, cam shaft seal, crankshaft seal, valve cover gasket, plugs, rotor, dist cap, wires, pcv, air filter, fuel filter, EGR valve, Throttle Position Sensor, Front Motor Mount and Dog bone.
Car runs very well except!!!! Now experiencing a feeling of vibration when approaching 2K rpm range. Seems to diminish as rpm exceeds the 2k range. All else is fine, power is good, just this dam vibration at that range.
Is it possible the crank pully(balancer) could cause this? Would really appreciate exerienced guidance here. Thanks.
