Loud Noise Clunking When Starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2008, 04:20 PM   #1 (permalink)
GoldenAgeCamry
View Purplehaza1987's Photo Gallery
4th Generation Loud Noise Clunking When Starting
Hi everyone I have 99 gen 4 Le ...purchased from auction everthing runs well great shape, but when i start the car i hear a loud noise like rattling/clunking for about two minutes and al of a sudden it dispears the enigne idles down and it sounds smooth as can be can anyone tell me what this is it sounds like its coming from the alternator belt area..all info appreciated...
as long as its warmed up it will not make noise i can shut it off start it and it sound good but if i let it sit for long periods of time the noise comes back...
Purplehaza1987 is offline   Reply With Quote
Old 05-11-2008, 05:34 PM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Does it stop once the engine has actually warmed up?
RichieRichJP is offline   Reply With Quote
Old 05-11-2008, 07:09 PM   #3 (permalink)
GoldenAgeCamry
yea it stops after about 2 min only when the car is not warmed it will make that noise
Old 05-11-2008, 07:45 PM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907127
iTrader Score: 59 reviews
May be the timing belt tensioner.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 05-11-2008, 09:18 PM   #5 (permalink)
I agree
Old 05-11-2008, 11:21 PM   #6 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
interesting, I have that sound also but more of a higher pitch. I've been told by a couple of mechanics that is could be a loose valve. They also said its not a big deal... Should I be worried?
btw, which is more severe?
cruisn76 is offline   Reply With Quote
Old 05-11-2008, 11:54 PM   #7 (permalink)
TRD lover
2000le4cyl's Avatar
View 2000le4cyl's Photo Gallery
got seafoam?
[SIGPIC][/SIGPIC]
2000le4cyl is offline   Reply With Quote
Old 05-12-2008, 02:13 AM   #8 (permalink)
GoldenAgeCamry
is that something that needs immediate care or can i still continue driving and is it an expensivve repair thanks, for the input above...
Old 05-12-2008, 11:22 AM   #9 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
How many miles on the odometer?
It may be worn pulley bearing on alt, p/s or water pump, Timing belt tensioner, etc.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 05-12-2008, 12:48 PM   #10 (permalink)
If you want your car to still be working you should repair it. You're going to have to pull the engine to reach the timing belt components and it'll cost a good bit to do that. A Couple hundred dollars easily.
Edit: Hajoca is also right on that. It could be a bearing too. You need to try locate exactly where that sound is coming from.
Old 05-12-2008, 01:35 PM   #11 (permalink)
Darkside Cut Me!!!
Belt tensioner would not require engine to be removed, but it is an involved activity with several components to be removed.... I take that no maintenance history is available.
2004 RX330 Sport
2003 Cam I4 XLE
Old 05-12-2008, 02:19 PM   #12 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I'm not sure what you mean by "rattling/clunking". You have checked/changed your oil, right? If the other items don't pan out I would pull the valve cover to make sure you didn't have a sludge build up. If you do have a sludge problem, I could envision that restricting the oil passage until the oil thinned out and finally getting to what ever parts are making the noise. Mind you, this is a guess. But it is easy to pull the valve cover, you just will need to pay for new gaskets (the main valve cover gasket and probably the spark plug tube gaskets).
Kep
