I don't think it matters but is it an I4 or V6? Is the motor turning over and not catching or is nothing at all happening when you turn the key on? Are the indicator lights coming on when you turn on the key? In the fuse box behind the battery, check the EFI fuse and the EFI relay for correct operation. I am unfamiliar with a "head" relay. Can you describe it better, as well as the clicking noise?
Luck,
Kep
