As for spark plugs, do not get bosch. If you can, get denso brand, as they are oem replacements for Toyotas. I've had decent luck with duralast plug wires, better quality than the bosch ones. The pcv and fuel filter from AZ will be fine. If you can't get densos from your local AZ, you might be able to get them from advance or oreillys, depending on where you live. Otherwise, get your spark plugs from the dealership.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
