How did you resolve your igniter trouble code?
I'm not sure how the cold start routine works on a 3SFE. It's almost like the car is sending extra fuel for the start up and then when it thinks it's running it stops the cold start routine and relies on the "regular" system. Could the old fuel have clogged up the fuel injectors and throttle body enough to affect it? Just random thoughts...
Kep
