95 camry, throttle stuck, constant accel
I got this camry used and in pretty good condition with only 93k miles on it. Recently I have gone to break at a stop light and felt the car struggling against me, and then it goes into a high rev acceleration when my foot is not even on the gas. I figured out the mechanical throttle was sticking so I moved it around a bit and sprayed it with some WD-40. It then drove as normal as it did before, but some 300 miles later the same problem occurred. In an effort to save myself from rear ending the car infront of me, I put it in neutral hoping it would rev but still coast. Instead the car slams to a complete stop.
My guess is that the engine heat dried up the WD-40 causing the throttle to stick again. Is there any lube that will withstand the heat? Is my transmission alright?
thanks
