how to check the flatness of a cylinder head? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2008, 07:58 PM   #1 (permalink)
View Camry-rulez's Photo Gallery
3rd Generation how to check the flatness of a cylinder head?
Hi!
I just whant to know how to check the flatness of a cylinder head? because I have assambled it all and now I whant to check if it if flat. the warpage is 0,1mm . can I check it whit something like a ruler ?
Euro CAMRY. 3.0 GX V6 (auto.) 1993'
Toyota Camry and Peugeot 205 Driver
Camry-rulez is offline   Reply With Quote
Old 05-15-2008, 11:06 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Originally Posted by Camry-rulez View Post
I have assambled it all and now I want to check if it is flat.
I've never done this but I always figured that you checked it before you reassembled it. If it was off you had it milled.
Kep
Old 05-16-2008, 07:45 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Kep's right, it's a little late to be checking flatness. "can I check it whit something like a ruler ?", yes if the ruler is certified flat. 1mm is about .004in so you'll have to research what the max tolerance allowance is. First take says the head gasket will compensate for .004in, especially if it's over the length.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
