95 camry 4 cylinder ATF question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2008, 01:49 AM   #1 (permalink)
View djfetus's Photo Gallery
i want to change my friend's camry's automatic transmission fluid. My question is, how many quarts does it need for a full flush, and what type is it? is it dextron? or genuine toyota brand atf fluid for type t-4?? please let me know thanks from mark
visit my camry at http://brokenfetus.com/mypersonnalvehicle.html
djfetus is offline   Reply With Quote
Old 05-15-2008, 03:46 AM   #2 (permalink)
Killer5sfe's Avatar
View Killer5sfe's Photo Gallery
Go to advance auto parts and get that new Castrol ATF for imports. It works awsome and smooths out the shifting. by the way Dextron, DIII and Mercon is for chevy and ford lol
Anyways fluid capacity is
dry fill: 5.9 qt, drain and refill: up to 2.6
Killer5sfe is offline   Reply With Quote
Old 05-15-2008, 04:05 PM   #3 (permalink)
View toyomoho's Photo Gallery
The 95 was made to use Dexron III, Dexron III is no longer made, find something that is equivalent. Any autoparts store should have something.
Don't use T-4 which is designed for later model trans.
If draining the pan only the 2.6 quarts will come out, the rest remains in the torque converter. You can do 3-4 drains drain and refills between short driving events to clean out most of the old fluid.
Old 05-15-2008, 07:54 PM   #4 (permalink)
awesome thanks
alright i'll try to flush out the system much as possible, when you mean 3-4 times of short driving, how far of a distance are we talking about? i kind of not want to drive the car without any fluid in the trans... if you know what i mean.
