Left Blinker Issues? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2008, 08:29 AM   #1 (permalink)
View BLACKHD01's Photo Gallery
Got in my car this morning and my left blinker arrow is lit up green, and the blinker lever is in the neutral position. When I put the lever to the left turn signal position it blinks one time then just stays lit. Got out of the car and both front and rear blinkers are lit up but not flashing. Right side works fine. Could this be a relay problem? Any help would be greatly appreciated.
BLACKHD01 is offline   Reply With Quote
Old 05-15-2008, 09:32 AM   #2 (permalink)
Toy_Dreamer's Avatar
View Toy_Dreamer's Photo Gallery
change your blinker fluid... haha
check the wires, and fuses. could have a broken wire or blown a fuse.
1998 Camry XLE | Black | Custom Halo Lights | Fogs | Infinity Kappa front speakers | Infinity Reference Sub | SRI Secret Weapon R...
Toy_Dreamer is offline   Reply With Quote
Old 05-15-2008, 09:38 AM   #3 (permalink)
Can you get the fluid at Autozone? Thanks for the help, I will check fuses and relays tonight.
1997 Camry LE 4cyl.
Old 05-15-2008, 11:34 AM   #4 (permalink)
Heat's Avatar
View Heat's Photo Gallery
Check the fuses and also check the bulbs to make sure one isn't burnt out.
I've never had a turn signal bulb burn out on my Camry, but on other cars the light would blink rapidly on the dashboard when a bulb was burned out - maybe on the Camry it just stays solid?
You didn't say what year your Camry was... on the '95 you get to the front turn signal bulb by taking a screw out of the lens (phillips screw), then the lens comes off and the light assembly slides out, it's sort of held on by a clip on the outer edge. Then unscrew the bulb from the back of the light assembly.
For the rear turn signal lights as wella s rear side maker and stop / tail lights on a '95, undo two Phillip's screws then the assembly sort of slides to the left (two small clips maybe?). Remove the bulbs.
There are some good illustrations in your owner's manual.
Heat is offline   Reply With Quote
Old 05-15-2008, 12:41 PM   #5 (permalink)
It's a 1997 Camry 4 cyl,both of the bulbs were burning this morning when I looked at them, must be a relay prob. or somthing like that, because you don't hear the clicking sound that it usually makes when you put your turn signal on.
1997 Camry LE 4cyl.
Old 05-15-2008, 01:08 PM   #6 (permalink)
mario4346's Avatar
View mario4346's Photo Gallery
Speaking of hearing the blinking.....is there a way to either mute it or deaden the sound it makes, it's super loud......at least on my Gen4.
mario4346 is offline   Reply With Quote
Old 05-16-2008, 03:52 AM   #7 (permalink)
View tran.man48's Photo Gallery
Turn the radio up
tran.man48 is offline   Reply With Quote
Old 05-16-2008, 04:08 AM   #8 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
Originally Posted by tran.man48 View Post
Turn the radio up
+1..
thats the relay clicking on and off that is making the sounds.. and it lets you know that the relay is working.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 05-16-2008, 12:45 PM   #9 (permalink)
Well checked the fuses, flashers, and bulbs last night all were ok. Get in the car this morning left green blinker signal still lit up. Went about 5 miles and the left blinker signal goes away and now the left turn signal works fine. So I don't know what in the hell is going on, maybe it won't mess up again. The night before this all started we had alot of heavy rain and alot of lightening, maybe some of the wires got wet or something who knows.
1997 Camry LE 4cyl.
