help: 98 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2008, 02:13 PM   #1 (permalink)
View hqfking's Photo Gallery
Question help: 98 Camry
This morning, after shopping, I found there is some water drops coming out of the bottom of the car.
I don't know what the problem is. Is it serious?
hqfking is offline   Reply With Quote
Old 05-15-2008, 02:22 PM   #2 (permalink)
View toyomoho's Photo Gallery
What general location under the car, the A/C system will drain condensation water from a hose to the ground in the front passenger area.
Might also be engine coolant. Feel and smell the fluid, coolant feels slippery and has a sweet oder. I
Old 05-15-2008, 02:30 PM   #3 (permalink)
it is around the front passenger area. And the fluid seems like the water.
Old 05-15-2008, 03:45 PM   #4 (permalink)
Gameroom cash: $303055
That sounds like the condensation from the A/C system as toyomoho mentioned.
Mike
Old 05-15-2008, 10:19 PM   #5 (permalink)
Armbrust6's Avatar
View Armbrust6's Photo Gallery
4th Generation
ya and drive your car with the windows down and make sure there isnt a burning smell because mine was like that and it was the oil pan seal was worn in a spot and oil got on my exhuast and it would burn when i drove it. dam it smelled bad! but ya if its just a little bit of fluid i wouldnt worry about it.
O and check your oil level to make sure.
Hope this helped.
Armbrust6 is offline   Reply With Quote
