Originally Posted by Nini
Thanks I'll get the codes. I heard you can get them autozone, correct?...I did replace the oxygen censors. I was told that's why the light keeps on coming back on. Now the light still is coming on after replacing both censors.
Don't be told anymore then
In the usa I believe autozone scans for free, get the codes and ask them what they mean, or even better report back here or search for them on the forums, you might end up realizing it's an easy fix.
Good point on clearing the codes when done, you can also disconnect your battery for about 15 minutes to reset your computer and have it run the scans again while you drive around.
Is the car driving fine? Do you have a V6 or 4 banger?
