AFM Mod - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2008, 01:19 PM   #1 (permalink)
View J_Phu's Photo Gallery
3rd Generation AFM Mod
Well I searched around already but am still curious what you camry owners have yours at. I was messing around with the afm and decided to lean it out a bit, I have it at about 7 clicks clockwise but I don't feel any diff. So what do some of you guys of your afm set at clicks wise
J_Phu is offline   Reply With Quote
Old 05-16-2008, 01:47 PM   #2 (permalink)
View Bear95's Photo Gallery
????????????????????????What is the afm that you are referring too
Bear95
Bear95 is offline   Reply With Quote
Old 05-16-2008, 02:00 PM   #3 (permalink)
its an Air Flow Meter. Its connected on your intake pipe and it has a flap that mesaures the resistance of the air thats coming into your engine. You can mess with the flaps on these things to have a leaner or richer mixture of fuel.
Old 05-16-2008, 02:09 PM   #4 (permalink)
Thanks for the answer, I have a 2.2 and it does not have one. I have a Intake Air Sensor on my car.
Bear95
Old 05-16-2008, 06:03 PM   #5 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
I'm not sure actually, my head gasket went when I was about to do the mod. I've read about between 7-14 clicks? Some going as high as 20 clicks, though I would becareful if I was you. There are stories of the car not starting if you turn it too much.
EvoFire is offline   Reply With Quote
Old 05-16-2008, 07:30 PM   #6 (permalink)
Damn 20 clicks isn't 14 more than enough. Thats running really lean you can destroy your car like that
Old 05-16-2008, 07:46 PM   #7 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
You always index where it was at before you work... I made that mistake and ended up messing up with mine. I found that 7-10 worked... and you feel it from about 3500 rpm to redline if you have the throttle pinned.
BlueFusion6851 is offline   Reply With Quote
Old 05-16-2008, 09:16 PM   #8 (permalink)
7-10. maybe I need to go more than 7 then. But is it safe to go more than 7. Oh and will this effect my emmisions??
Old 05-16-2008, 10:52 PM   #9 (permalink)
engineer in training
Gameroom cash: $145055
There is no telling exactly what you are doing to the air fuel ratio, you need to borrow a wideband and get a bung welded in to measure the change in fueling. The thing is one click on the AFM is not the same amount of fuel as another click, you are dealing with a very worn out spring and everyone's will be a little different.
Old 05-16-2008, 11:31 PM   #10 (permalink)
Good point I never thought of that, But will it hurt my emmissions if I lean it too much
Old 05-16-2008, 11:35 PM   #11 (permalink)
Yes, leaning the mixture heats it up and will increase your NOx emissions, though it may drop your carbon emissions slightly too...
Old 05-16-2008, 11:56 PM   #12 (permalink)
so if it heats up then thats a bad thing, then I should just leave it as is then
Old 05-17-2008, 12:10 AM   #13 (permalink)
If you have emission testing I wouldn't mess with it honestly.
