Screeching sounds after power steering / AC belt change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2008, 08:34 AM   #1 (permalink)
Mahonri's Avatar
View Mahonri's Photo Gallery
Hello All,
I changed my power steering and AC generator belts a couple months ago when the weather was still cool. Everything was fine. Now that it is summer time here in Texas, things have warmed up a bit and both of these belts are squealing like pigs.
I'm guessing that I did not tighten them enough since the squealing is worse with warmer weather and the belts have expanded a little.
Does anyone have any advice for me?
Thanks!
Mahonri is offline   Reply With Quote
Old 05-17-2008, 09:32 AM   #2 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Check your belt tension.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 05-17-2008, 09:36 AM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I agree with your logic and that is what happens with loose belts. An old rule of thumb to see if the tension was correct was that you should not be able to twist the belt much less than or more than 90 degrees by hand. If you can turn it more than 90 degrees in the middle between the pulleys then it is too loose. This isn't precise but it works fairly well.
I'm not sure about the expansion idea (I think the metal pulleys expand about the same if not more). However, maybe the tensioning mechanism has gotten loose.
Kep
Old 05-17-2008, 02:37 PM   #4 (permalink)
Gameroom cash: $303055
The belts do stretch out a bit after a few hundred to a few thousand miles of usuage. In my experience the power steering belt is the one that stretches the most. Also aftermarket belts stretch more than OEM belts. I would recheck the power steering belt first from underneath the car.
Mike
Old 05-28-2008, 11:57 PM   #5 (permalink)
View FishyMan's Photo Gallery
How often should I change belts? i'm nearing 50k.
and we have 2 drive belts right?
FishyMan is offline   Reply With Quote
Old 05-29-2008, 09:36 AM   #6 (permalink)
View nikita's Photo Gallery
Its not miles, but condition. Too many variables to set a mileage. Environment, heat, cold humid, dry, smog, etc. matter more. Inspect for fraying and cracks. If none, leave them alone.
nikita is offline   Reply With Quote
