Still Down on Power?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2008, 04:56 AM   #1 (permalink)
Tech In Training
View Gun5's Photo Gallery
Well I had a thread a few weeks ago saying the car was slow as hell and it just doesn't pull at all.. Well I just buttoned it up tonight after working on it and its actually slower now barely get up to 50-60
Just finished the below
Cam Seal, Oil Pump Seal, Front Main Seal, Timing Belt Set, Both Belts, Wires, Plugs, PVC Valve, Torque Rod, Seafoam/Oil Change, Dist Cap/Rotor
I lined up the marks perfectly.. but there is a few things that could have it a tooth off.. what direction are you supposed to be looking at the crankhub's "0" from? the fender from the top or the front of the car?..
also on the camshaft I lined it up with the slit not the dot I'm going to take out the timing light and check the timing tomorrow but I seriously doubt that is going to fix it since it just got worse doing the timing belt
2000 Camaro Z28 - Full Bolt ons, Heads/Cam
1994 Firebird Formula - Full Bolt ons, Heads/Cam *Parted Out*
Coming Soon 1995 Camry LE 165k
Gun5 is offline   Reply With Quote
Old 05-19-2008, 10:28 PM   #2 (permalink)
Tech In Training
took off the dist today to do the seal, going to time it hopefully tomorrow see how it comes out.. checked compression a week or so ago definitely had 170-170-180-180 nothing was under Toyota's specs
oil pan is still leaking for some reason though even though i'v tightened it up more
Old 05-20-2008, 08:21 PM   #3 (permalink)
Tech In Training
timed it today to 10 definitely running alot better. the PS is still whining when turning put a new belt on it changed its fluid and the belt is tight dunno what its deal is going to losen and tighten it one more time
Old 05-20-2008, 09:19 PM   #4 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
the rule of thump that i was told was if you can turn the belt 1/4 then your good...
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 05-20-2008, 09:55 PM   #5 (permalink)
Tech In Training
turn the belt? are you meaning how much you can make the belt deflect tight?
Old 05-20-2008, 11:26 PM   #6 (permalink)
Black95Cam's Avatar
yeah..
Old 05-21-2008, 07:52 AM   #7 (permalink)
Tech In Training
it doesn't deflect that much but I'm going to redo it tomorrow.. I had noticed the timing cover had a line wore in it from the last belt and this one is rubbing too even with the timing cover tightened down the pulleys don't wobble and are straight so I'm at a loss there but it shouldn't affect the tension of the belt.. just sick of it slipping when you turn you can hear it
Old 05-21-2008, 07:52 AM   #8 (permalink)
Tech In Training
it doesn't deflect that much but I'm going to redo it tomorrow.. I had noticed the timing cover had a line wore in it from the last belt and this one is rubbing too even with the timing cover tightened down the pulleys don't wobble and are straight so I'm at a loss there but it shouldn't affect the tension of the belt.. just sick of it slipping when you turn you can hear it and then sometimes you can hear it rub the cover under the hood
