Are you loosing coolant?
Does your oil appear milky?
If so, it is probably a blown head gasket.
It sounds kind of extreme. If you have decided to replace the gasket ($650 isn't bad) or replace the engine you might first want to try an additive (since you've given up on the engine as it is). Since the car stalls out, I don't know if you'll be able to get it to work or not. Wal-Mart sells CARGO (about $5) and you can get STEEL SEAL (much more expensive, $30, but supposedly works better) on line. One of the factors for success is the size of the hole. If it is too big they won't be able to fill it. Read their directions and see if you're willing to work with it.
Luck,
Kep
