Hood Shaking? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2008, 09:05 AM   #1 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
3rd Generation Hood Shaking?
Ok so i need some help! Around speeds between 50mph and 90mph my hood gets caught by the wind. No i usually know how to fix this just by tighting the lock and i even had my friends car shop look at it and we are clueless.. there is noway to tighting it? i just want my hood to lockdown nice and tight so it doesnt move cause its kinda starting to get really annoying! any help would be greatly appreaceated!
Chris
Spitfire is offline   Reply With Quote
Old 05-21-2008, 09:25 AM   #2 (permalink)
View louie1086's Photo Gallery
your hood might vibrate because there is a gap between the hood and the rest of the car where there normally isn't, due to damage to the hood, causing fast moving air to catch under the hood forcing it to move up. the pressure from the air moving over the hood forces it to move back down. this cycle creates vibration in the hood.
another possibility is that your hood latch is too high up, again causing air to flow where it normally shouldn't. adjust your hood latch all the way down. there are also rubber hood supports on each side of the frame located close to the headlights. you can try adjusting those.
check to make sure the bolts holding the hood and the hinges are tight to specification. loose hardware will amplify vibrations in the vehicle.
Rides:
96 Emerald Green Metallic Camry LE (R.I.P)
09 Classic Silver Camry LE
louie1086 is offline   Reply With Quote
Old 05-21-2008, 10:05 AM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
In my 95 model there are two rubber bumpers on the front corners that the hood rests on when it is closed. These can be screwed up and down to adjust the tightness of the latch. The 90 model had metal bolts that the bumpers were fixed to. The 95 model has spiral threads cut into the bumpers themselves.
Kep
Old 05-21-2008, 11:53 AM   #4 (permalink)
JDM Inspired
Spitfire's Avatar
3rd Generation
Kep
Mind snaping some pics for me ? im still a lil confused. but atleast now i have an idea
Old 05-21-2008, 11:55 AM   #5 (permalink)
JDM Inspired
Spitfire's Avatar
3rd Generation
Its deff the 2nd one cause i have no large gaps, they are all flush and in order. My car has no recorded wrecks in its past and has all of the orig body pieces on it. So if kep doesnt could u tak a pic to show? i have an idea but im in school atm and cant go out and look to like 4 lol.
Old 05-23-2008, 11:16 AM   #6 (permalink)
Kep
Kep's Avatar
No time to post pics right now. These are about 6" behind the headlights and about as far outboard as you can get. They are about 1" in diameter. When the hood is closed, the two front corners rest on top of them.
Kep
Old 05-23-2008, 10:42 PM   #7 (permalink)
Banned
View Vagisimo's Photo Gallery
does the hood move while you are driving, from wind catching it?, go and try to move the hood up and down like you are trying to open it, but leave the latch closed, if it moves, open it and look for gaping holes directly above the headlights that should have rubber bump stoppers in them, someone probably removed them to reduce the weight of the car, to increase gas milege, if there are rubber things in gthere, then look closely, you can adjust them, unless they have been replaced with hood bumpers from an old for dickup truck, in that case youre screwed.
Vagisimo is offline   Reply With Quote
Old 05-23-2008, 10:54 PM   #8 (permalink)
Banned
i meant to say ford pickup truck, good quality cars IMO
Old 05-24-2008, 07:24 AM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Both of my Camrys do the same thing..but my rubber adjusters are all the way up. Ive got to check out the latch.
Ill take a pic of them for you. Give me a few minutes. BRB.
EDIT:
Here ya go.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 05-24-2008, 10:19 AM   #10 (permalink)
JDM Inspired
Spitfire's Avatar
3rd Generation
hmm ok ill look today cause now i know what ur talkin about lol! ill look in a lil tho cause i just woke up but yes my hood u can move up and down with hood closed. hmm
Old 05-24-2008, 10:20 AM   #11 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
mine's been wiggling for years and ive never bothered with it .... at least 5 years (since i moved to TN)
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 05-24-2008, 11:44 AM   #12 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
buy a CF hood and hood pins .
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 05-24-2008, 08:52 PM   #13 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
i did that to mine and it reduce the shaking but oh well...
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 05-24-2008, 10:26 PM   #14 (permalink)
Electronics master
View cmjohnson's Photo Gallery
The purpose of those rubber covered adjustment screws is to level up the hood's surface with the surface of
the fenders. They don't serve any other purpose but do incidentally have an effect on how tightly the hood
latch holds down the hood.
For just a few dollars, go to the Toyota dealership near you and order a replacement set of the rubber
gaskets that are secured to the underside of the hood with snap-in fasteners. They serve a purpose
and you just found out what it is. if they're in good condition, and they're present, the hood won't shake
at any speed.
CJ
cmjohnson is offline   Reply With Quote
Old 05-24-2008, 10:34 PM   #15 (permalink)
at any speed.
CJ
Any pictures of what YOU are talking about? I adjusted my latch all the way down and it still shakes. My rubber pieces that I took the picture of above are all the way up. Id REALLY appreciate it, as both my Camrys are doing that.
