I am running the standard rad, altho I'm not the only one that has done that. TBH is is too good at cooling on the 4AGE and the fans never kicked in when it ran stock. A few other guys are using the same setup with no issues so I don't think there is a problem there tbh, its a new rad as well so should be up to the job. At some point I will hopefully get a different rad but for now this is all I have, altho might upgrade the fans and have them put on a switch so I can determine if I wwant them on rather than a temperature sensor in the bay.
I'll definatly be ordering a thermostat when I order the head bolts as I don't know how long the other has been on or in what condition the existing one is.
I've had a few gaskets go now on various mr2's and as you say its usually an eruption of coolant so perhaps the gasket is fine, still as I have a new one already I might as well go ahead with swapping it out I spose. At least I know it will be good for a while then.
I'd love to be polishing and porting the block but might have to wait until the next build of the lump (might even get a second engine if I can find one at a decent price). Can then go to town on it and build up a nice not so low boosted engine. There is a guy who would do it for me but I just can't afford to spend out much more at the moment, got some more plans involving nos. both on the V6 and my bike.
This is definatly only the first build unless I can get hold of a 5vz and then I'll just use that instead and swap this engine into a mk2 to sell.
I'm sure it was a new pipe we used but will check that again anyway, its definatly worth looking.
Cheers for the help guys.
I just hope I can get it sorted soon as have a lot of other things to do to this car other than the engine. and driving the track car daily is a bit of a pain
