Electrical - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2008, 08:36 PM   #1 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Electrical
The rear passenger door window does not work with power window master switch, or from the rear passenger door switch. Also the Power lock does not work on the door only.
So that rules out fuses, so what next to check, breaks in wires that go to the door, maybe bad ground?
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 05-21-2008, 10:04 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check the Blue wire at the window switch for power.
Which side rear door?
Old 05-26-2008, 08:30 PM   #3 (permalink)
Mr.Nutcase's Avatar
The rear right one, ( as if sitting in the driver seat)
Also the power lock for that door does not work.
Old 03-21-2011, 12:54 PM   #4 (permalink)
Mr.Nutcase's Avatar
Well after using the wiring diagrams.
I found out that the wiring harness going to motor had open,
I fixed that, well it did not work.. I had voltage in both up and down
I thought it was the power window motor, I used battery and jumper wire with fuse
The window works.
With the window working I next possible problem was the power master switch.
I removed it, and I test with DVOM
I found that there was no reading when testing the switch.
I bought one from the junkyard, now the window works.....
