Originally Posted by Mike Gerber
It's inside the distributor.
Mike
Thanks Mike.
I'm having this intermittent problem where the engine hesitates every second or so when the rpm takes a dive and the lights dim down. I had it "diagnosed" at the stealership and they told me that the wires and the ignition coil is bad and suggested replacing them including the sparkplugs. I replaced the wires, plugs, distributor cap, and the rotor only three months ago when the problem appeared but it didn't cure it. Anyway, I suspect it might be the ignition coil that's causing these hiccups. Is there any way to check whether or not the ignition coil is operating correctly? Can Autozone/Checkers test it for you?
I found this guy selling new aftermarket coils for thirty bucks (including shipping):
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
What do you think? Do you think it's a good product? Thanks much for your help.
