Help in removing codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2008, 01:16 PM   #1 (permalink)
View mdmm's Photo Gallery
Since last six months I removed following codes with my OBD-2 many times but they come back.I replaced with new gas cap.no difference.
Toyota camry 4 cylndr 2000, 150000km.Codes are
P0401
P0441
P0446
Please help me.
mdmm is offline   Reply With Quote
Old 05-27-2008, 05:07 PM   #2 (permalink)
View toyomoho's Photo Gallery
If both P0441 and P0446
Malfunction in VSV for EVAP, VSV for vapor pressure sensor, vapor pressure sensor.
Vacuum hose cracked, blocked, etc charcoal canister leak, cracked, fuel tank overflow check valve leak.
Canister, lines or valves-low pressure in canister, not purging OK.
P401 Exhaust gas recalculation flow insufficient detected.
The engine is not getting enough recycled gas from the EGR system. Causes could be stuck closed EGR valve, defective EGR VSV, MAF or MAP sensor, and EGR vacuum hose leaks. The actually EGR valve or the gas tube running to it may be plugged with carbon up, they can be removed and cleaned.
Old 06-12-2008, 09:16 AM   #3 (permalink)
I paid to the mechanic.He took out EGR valve and cleaned egr valve and its tubing with spray and then pressure wash.He put it back.After one day i did not get the codes po441 and po446 again but i got new code po401 ??
Please let me know what is it.My gas cap is tight.Do i need to replace with new gas cap or should i replace the Exhaust drum on back of my Camry-2000,4cyl, 150000KM .
Old 06-12-2008, 02:37 PM   #4 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
hey man i had that code and ima save your the ead ache.
check to see if your EGR valve isnt sticked by connecting a vaccuum to itif teh car stalls adn then deis that means its doing its job.
next go to teh modulator ( this is what was giving me my problem ) get a new one from the dealership or from a online source make sure the vaccuum line to the modulator are clean adn your code should be gone...that like a 20 min job...or leas good luck
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 06-12-2008, 03:24 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
^holy spelling problems batman..... damn... can't even understand that.
p0401 is insufficient EGR flow.
I think your problem is a bad vac hose going from the throttle body to the actuator and to the vsv's... that would cause the egr problems, and the vsv problem if there was no vacuum to the actuators...
check all the vac lines on the top of the motor.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 06-12-2008, 10:19 PM   #6 (permalink)
Creeps228's Avatar
sorry man is just that i spilled soda on the keyboard and the keys are sticking...but its most likey the modulator thats the convict in this problem...its not the hoses, trust me i lasted an entire year with that code
MR2: 7A-GE
Old 06-13-2008, 06:45 AM   #7 (permalink)
You mean I must clean or replace EGR Modulator???
Please let me know where is EGR modulator or other suggested part exactly located on Camry2000 4cyl. front side of engine?.I am a new person .Can I do it ??
Do I need to replace VSV valve???
Old 06-14-2008, 12:14 AM   #8 (permalink)
Creeps228's Avatar
the modulator is located right next to the EGR valve, its the brown thign swiht the silver circle with red lining you cant miss it. i dont have a pic of it but the EGR valve is blue and the Modulator is brown/black..id say dont clean it get a new one, unless you feel you can lean it out yourself i tried but it didnt work. About the vsv dont change it until you check out the modulator since the vsv ius the next most expensive thing for the exhuast recirculation system and then it the EGR valve itself. Change your modulator and check if the codes comes back on...
MR2: 7A-GE
Old 06-16-2008, 05:36 AM   #9 (permalink)
SIR,
Thank you very much for help.
I will do all that tomorow.Today morning i got the light back and am getting three previous codes, PO441,PO446,Po401.
I saw a sonsor behibd EGR valve in my Camry2000.It say"" Toyota , Sensory Assay , VAC, 89420-060 40 and at the bottom is a number, 0136 .
Please let me know what is this sensor about and Do I need to clean it or replace it also if it may be causing the problem ???
Old 06-18-2008, 10:39 AM   #10 (permalink)
Toyota-Camry-2000
Thank you very much Sir.
Under your guidance by pdf pictures and repair notes,I clean EGR Valve and EGR modules and conneted all tubings.since last 2 days code po401 is gone.Now i am only getting two codes po441 and Po446. Now what is suggestions,that a quite new person like me can do with minimum money matters,please.
Do I need to clean or replace VSV switch or valve.Do I need to clean or replace charcoil canister by new or used??
Where is charcoial canister located??Is it a big drum on back bottom of Camry2000???
Old 07-27-2009, 08:58 PM   #11 (permalink)
View jandrews's Photo Gallery
USA
Im having the same problem too. Heard its the cannister at the bottom of the car.
jandrews is offline   Reply With Quote
Old 07-27-2009, 10:44 PM   #12 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
It's the VSV on the canister on the rear axle subframe. You may be able to carefully pry open the metal fingers and clean/lube the VSV plunger.
The generation of canister seems to have some defects, either in design or manufacturing. The charcoal can disintegrate and blow powder all over the system plugging things up causing codes.
But I think in your case it's simply the VSV sticking with age. Another problem VSV is the one on the filter housing that vents into the intake.
Old 07-27-2009, 10:45 PM   #13 (permalink)
VSV should look like:
http://www.rockauto.com/catalog/moreinfo.php?pk=817604
Old 07-27-2009, 10:47 PM   #14 (permalink)
Looks like a different design. Not sure how easy to pry apart the metal tabs here.
Old 07-28-2009, 11:37 AM   #15 (permalink)
3rd Generation
I dont see the VSV by the cannister though....I see something similar to the picture right by the throttle body. Is that the same VSV?
