92 Camry Antenna Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2008, 10:50 AM   #1 (permalink)
View MineralGray02K's Photo Gallery
3rd Generation 92 Camry Antenna Question
My antenna goes about halfway up, then stops. It definitely makes radio reception worse, and I definitely need to fix this soon. It goes up and down no problem (just goes up halfway). I am looking around online and see a lot of antenna mast's.
Should I buy an entire new antenna or a new mast? Thanks guys!
1992 Dark Emerald Pearl Camry V6 LE
http://camry.mikefordmustang.com
New York Mustangs - NY Mustang Club
http://www.NewYorkMustangs.com
MineralGray02K is offline   Reply With Quote
Old 05-28-2008, 11:51 AM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
JUST the mast. It's probably the most common issue on our cars. I replaced mine 2 times in 1 year a while back, lol. PepBoys sells a direct replacement for our car for $19.99 I think.
5 Lug Corolla WHAT?
Old 05-28-2008, 05:20 PM   #3 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
would you consider doing the S2K antenna mod.
TheKevin is offline   Reply With Quote
Old 05-28-2008, 05:39 PM   #4 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
^ I have and the reception lost is minimal to me
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 06-04-2008, 09:09 AM   #5 (permalink)
What exactly does the S2000 mod entail? I'm down for whatever, how much does it cost though?
Old 06-04-2008, 09:40 AM   #6 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
It'll run you $65 or so. I got the S2000 antenna on eBay for around $20. The other parts I got from the dealership for $45.
Here's the DIY link which includes all the part numbers you need.
http://www.toyotanation.com/forum/t65507.html
It may sound a little steep at first, but 1) it looks good and 2) you don' t have to worry about your antenna freezing up or down in the winter and 3) you don' t have to worry about your power antenna breaking any more.
I haven't experienced any degradation in reception and haven't seen anyone report on TN that they have either.
Good luck
eddie926 is offline   Reply With Quote
Old 06-04-2008, 09:22 PM   #7 (permalink)
View psyanyde's Photo Gallery
yeah hte S2K conversion's sweet
my buddy did it on his camry and he hasn't lost any signal.
I"m waiting for my ant to die before I spend any money on it
try WD40 first.. and really grease that puppy up to see if it helps.
it did on mine at one time.
1993 Camry V6 LE 4 Dr - 236K as of Feb 2008. All Stock.
psyanyde is offline   Reply With Quote
Old 06-04-2008, 09:31 PM   #8 (permalink)
I WROTE the DIY and I;m the only one to experience a crappy signal, I swear....lol. ONLY with AM though. If you only listen to FM, it;s fine. If you listen to a lot of AM, it;s not a good idea. I ended up doing another custom antenna so I could get AM good.q
5 Lug Corolla WHAT?
Old 06-04-2008, 09:42 PM   #9 (permalink)
View SmartedPanda's Photo Gallery
Irony sucks.
1992 Camry. 4dr Sedan. 3rd Gen.
2.2L 5S-FE I4, with ~167K Miles.
Trying to get my baby restored...
So Far: Dual XHD-6425
SmartedPanda is offline   Reply With Quote
Old 06-04-2008, 10:00 PM   #10 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
From taking apart a couple of the masts, what seems to happen is inside there's a rubber seal for each metal end of the antenna mast. What seems to happen is over the years, this rubber gets to the point it just binds, hence it won't go up all the way, or down all the way as the case may be, and obviously not something you can just take apart and fix.
For now looking at just putting a switch in to put it up only when I needed it for now. Down the road may do the S2000 mod. We'll see.
cykaaro is offline   Reply With Quote
Old 06-04-2008, 10:00 PM   #11 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
I did the S2K mod too, and I would say that my FM reception is pretty much the same and the AM is only slightly worse, but nothing of too much concern.
But the reasons as summed up above are more than enough to do it IMO
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
Old 06-04-2008, 10:10 PM   #12 (permalink)
xjfish's Avatar
View xjfish's Photo Gallery
I lubed mine up, pulled it all the way out and unplugged the motor from inside the fender/trunk. Reception is as good as new and no more grinding/binding. Free "fix". I would like to replace the power antenna altogether as I did in my old acura but reception is a big concern to me..
93 Camry V6 XLE ~ 310,000 miles
90 JDM Acura Integra GS
83 Mustang ragtop 5.0/T-5
xjfish is offline   Reply With Quote
Old 06-05-2008, 08:40 PM   #13 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Just wanted to add I replaced just the mast last year on my mom's gen 3.5. It was quick and now the antenna works again. I'm just sticking with the power antenna setup, it's the classic gen 3 look and it's cheap .
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 06-05-2008, 08:58 PM   #14 (permalink)
Strum's Avatar
View Strum's Photo Gallery
Mine is stuck in the up position, better than down (we are still talking antenna's). When I turn the radio on or off I can hear the motor trying to pull or push the antenna, but it just stays in the same position. I figure the gears are shot.
I do like that conversion and will have to consider that when I get the car back on the road.
Mark
1993 Camry 6 cyl. (142K),
1998 Camry 4 cyl. (140K)
1996 Corolla (227K), 1997 Corolla (167K),
Strum is offline   Reply With Quote
Old 06-05-2008, 09:10 PM   #15 (permalink)
Newbie
View 94cylcamry's Photo Gallery
Ours was like that for awhile before we got a new motor. You may as well just disconnect the motor and leave it in the up position if it's not working..
1994 Camry LE 5SFE
160,000 miles[12/2/08]
94cylcamry is offline   Reply With Quote
