Every time I put my foot on the break, even just lightly press it down, I hear a high pitch screach or something coming from what seems to be my front right break or wheel area. I can literally just start pressing the pedal, before its even slowing the car down, and the noise will start.
Any ideas what this could be? Easy fix?
1992 I4 Manual Camry - 294 000 Km and going strong.
1000W RMS in the trunk :P
Mine ('95 LE) does the same thing. I've taken it to my mechanic twice, he just says that it's a sticky caliper. He cleans it off and it's fine for a little while, then starts back up.
check the brake pads/shoe (if you have drums in the rear)
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
Originally Posted by Nevalite
It's a '92 Camry, is it possible I have drums all around? Or do I have to have disks in the front? Simply cleaning it will fix it?
Thanks
If you have the 5SFE 2.2, you have front discs and rear drums. If you have the V6 3VZFE, you would have discs all around.
Black95Cam is suggesting to check the pads in front and shoes at back. Not a bad idea.
Since you are saying that it's a loud screeching sound, cleaning would not fix the problem. My friend had the same thing and he had to replace the front pads because they were worn to the metal!
1997 Toyota Camry LE I4
@ 193,000 miles
The front disc pads may be worn down to the pad wear indicators. Pad wear indicators are little metal tangs that are designed to contact the rotors and make a high pitched noise, when the pads wear down to the point where they need to be changed. There are other things that can cause break squeak, but this is the most likely cause if it came on suddenly and the break pads have been on the car for a period of time. Have someone check the thickness of the front brake pads.
what mike says. DO SOME CAR MANTAINANCE!! simply by taking care of your car you will have no problems what so ever. its easy to do. oh and heat, change mechanics. ok im done.
2009 Camry--Super White
1997 Ford F-150 XL, 4.2L V6 5-SPEED 1 Owner
1970 Turbocharged 1915cc Beetle Sedan
1971 Lime Green 2332cc Beetle Sedan (Soon)
When my 1999 Camry Le starts doing that it means it's time to change out the pads.
After I change the pads the sounds go away. Happens about once a year.
__________________ Problems I've fixed with the help of this forum: The brakes squeak annoyingly. Problems I still need help with: Driver lock button locks all doors BUT driver's door. Driver electric seat buttons and gas door switch don't work.
Thanks
Front disk brakes became mandatory here in the US starting with model year 1977. Not sure about Canada.
Also, if your car has the optional antilock brakes and it has the 4 cylinder 5SFE engine, you will have 4 wheel disks. If the car is a 4 cylinder and is not equiped with antilock brakes, you will have front disks and rear drums. If it is a V6, you will also have 4 wheel disks.
I talked with the mechanic that lives in front of me and he said exactly what mike said, tomorrow we'll be checking the pads and installing some new ones Thanks guys
Mike
my 97 5SFE with ABS has front discs and rear drums. I thought I had 4 discs but I checked today and it had rear drums. Time for rear disc conversion! Good thing my ABS works.
Hey,
Get some ceramic brake pads and while you're at it, resurface the front discs. If they cannot be resurfaced, replace them with new ones.
google some information to have an idea about brakes.
@ 193,000 miles
"my 97 5SFE with ABS has front discs and rear drums. I thought I had 4 discs but I checked today and it had rear drums. Time for rear disc conversion! Good thing my ABS works."
The original poster has a 92 Camry. At the time the generation 3 Camrys were manufactured (1992-1996), I don't believe the technology exhisted to do antilock brakes with rear drums. That's just my eductated guess. When you opted for ABS brakes on a generation 3 Camry 4 cylinder, the rears had to be upgraded to discs. It was also an expensive option. I ordered my 1994 Camry 4 cylinder XLE with ABS. It was an $1100 option back then. By the time the generation 4 Camrys came around in 1997 the technology had changed. The generation 4 Camry 4 cylinder cars then came with front discs and rear drums with ABS.
The best thing is to change your rotors/pads and observe it and go from there.
Screech and weird sounds are not normal IMO. Just make sure you have fresh brake fluid and new rotors and new pads installed properly. Sometimes high pitch sounds are indication that pads need to be changed.
