14 inch vs 15 inch wheels/tires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2008, 09:15 PM   #1 (permalink)
View mtmx46's Photo Gallery
3rd Generation 14 inch vs 15 inch wheels/tires
Has anybody done the switch from the DX Camry's 195-70-14 wheels/tires to the SE's 205-65-15 wheels/tires?
Specifically, I want to know if your ride improved. I have brand new KYB-GR2's all around. How is that combination (the 15 inchers) on potholes and road cracks? Do you get a lot of intrusion into the cabin and floorboards?
I actually want to soften my ride. I think in a year or so when the struts wear a little it probably will loosen up a little, but it's pretty d#$m stiff for an old guy like me.
Matt
StillTikin96, 1996 Toyota Camry Four Door, 2nd owner
5SFE Automatic - 348,784 km
Studded Winter Nexens on 14" steel rims
Running Castrol 5w20 for now
mtmx46 is offline   Reply With Quote
Old 05-31-2008, 11:20 PM   #2 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
205/65R15s will fit fine, but if you want to keep your speedometer accurate as possible, go with 205/60R15s.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 06-01-2008, 04:15 AM   #3 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
205/65 has higher sidewall meaning more comfort but it will be a bit off on the speedometer nothing serious but it won't be super accurate.
felonyr301 is offline   Reply With Quote
Old 06-01-2008, 10:28 AM   #4 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
If you do stock 15's, use 205/65/15 tires. I really do not think you will notice ANY ride quality difference. But it would make the car look nicer.
5 Lug Corolla WHAT?
Old 06-01-2008, 10:28 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
the spedo will be fine with either. you wont have to worry bout that if your making as small a change as 60-65 on such a narrow tire anyways. as for comfort the 14s will be better. more side wall will be more comfortable.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-02-2008, 11:53 PM   #6 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
The comfort comes down to the tire you chose. My Camry had 14" wheels from the factory, but I now have a set of 15" wheels from a 2002 Camry. It's hard to make a direct comparison as my 14"ers were shot to hell (bald).....but everything did improve, quieter, better ride, handling, grip (obviously). Do it!
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 06-03-2008, 12:11 AM   #7 (permalink)
No longer in use
View lgcongbach's Photo Gallery
did gen 3 factory come with 14' or 15' ?
my 93 LE has 15' (never known that until this morning) for how long God know ...
what is the recommended size anyways ? I've seen some member going for 17' even 18' ...
lgcongbach is offline   Reply With Quote
Old 06-03-2008, 12:13 AM   #8 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
the speedometer will be 3% off ... thats enough of a difference IMO, but some ppl dont pay close attention to speeds, so it all depends
your handling characteristics wont change much, thats not why they put them on the SE model ... its purely aesthetics
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-03-2008, 01:51 PM   #9 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
Both were OEM, with the size depending on which options you got. If you opted for ABS or the V6, you got 15" wheels (and disk brakes on the rear). Everything else got 14"ers. Springing for the XLS package might have gotten you 15"ers too, I don't recall for sure.
BMR is offline   Reply With Quote
Old 06-03-2008, 01:53 PM   #10 (permalink)
Venom_5's Avatar
not all ABS models had 15" wheels ...
my car is a 95 LE with ABS (all around discs brakes), and i have 14x5.5" steel
Old 06-03-2008, 03:04 PM   #11 (permalink)
I HAS BOOST!!!
bigbird's Avatar
i may start to be concerned about that after 100mph but then again, at that speed your likely going to jail anyways.
R.I.P.
Car Domain:
Old 06-04-2008, 01:03 AM   #12 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Thanks for the correction. I should've mentioned that's how it was when I got my '92. Things must've changed.
