How do I change the ignition coil? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2008, 12:33 AM   #1 (permalink)
View wahed3001's Photo Gallery
Hello,
I need to change the ignition coil of my 1994 Toyota Camry I4 5SFE (non California). Do I have to take the whole distributor assembly off to change the ignition coil or can I take it out after removing the distributor cap, rotor, and the dust cover only?
Thanks
wahed3001 is offline   Reply With Quote
Old 06-02-2008, 11:00 AM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
http://www.autozone.com/addVehicleId...00c152800741d2
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 06-02-2008, 02:04 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The four mounting screws for the coil are on the bottom, so yes, you need to remove the distributor body (DB). Remember to mark the DB relative to the engine block. I like to use two match marks just to be sure. This way when you put the DB back on its in the same orientation as when you removed it so you don't have to re-time the engine. The engine block is aluminum so it is best to use a torque wrench when refastening the two bolts that hold the DB on. There is an o-ring between the DB and the engine block. This will probably be old and hard. Replacing it would be advised. Even though it only goes on one way, remember the orientation of the rotor so the DB goes on nice and easy. Be gentle with the wires to the DB and the coil. They are probably old and hard, easy to break the insulation.
Kep
Old 06-02-2008, 10:39 PM   #4 (permalink)
Kep
Great instructions Kep; thanks!
Old 06-02-2008, 11:14 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
ive always had respect for Kep's advice... keep it up! good stuff.
Dave Zoni
