Hissing. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2008, 06:23 PM   #1 (permalink)
EverReady's Avatar
View EverReady's Photo Gallery
Hissing.
Today I was coming home from school and I noticed a hissing sound. I pulled over look for and liquid leakage nothing. I figured im set it might just be an exhaust leak.
So above 2.5 grand I get a hissing sound from about mid body of my car 4 cylinder. It wont make the sound in neutral, and makes alot of hissing in second.
My problem is I can't get it to hiss unless im in gear moving with atleast 2.5G. So I cant use my ears.
I was thinking exhaust leak but it sounds way to high pressured to be a exhaust leak. My buddy said vacuum hose but I know nothing about that system to trouble shoot or even where to find the hoses.
So its a 4 cylinder with no liquid leaks, 93, I take good care of this car..
EverReady is offline   Reply With Quote
Old 06-03-2008, 06:26 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
notice if its running any different?
it could very well be an exhaust leak. theres alot of pressure in an exhaust system especially as it raises up the rpm range.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-03-2008, 06:29 PM   #3 (permalink)
EverReady's Avatar
I noticed a slight preformace drop not much def notice it in second.
But if its an exhaust leak why dont I get the hissing sound in neutral?
Old 06-03-2008, 06:35 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
same reason i only hear my exhaust leak in reverse. when the engien is under load then it can change the pressure in exhaust to a degree. but if your loosing performance then that may not be an exhaust leak. can ya get a clip of it?
R.I.P.
Car Domain:
Old 06-03-2008, 06:53 PM   #5 (permalink)
EverReady's Avatar
The best I can get of it. The performance drop might be in my mind though.
Old 06-03-2008, 07:00 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
yeah that sounds like an exhaust leak, prolly after the cat too. ull want to get under there and have a look to make sure.
R.I.P.
Car Domain:
Old 06-03-2008, 07:00 PM   #7 (permalink)
EverReady's Avatar
okay thanks.
Old 06-03-2008, 07:07 PM   #8 (permalink)
EverReady's Avatar
I jacked the back up got under no visible holes or anything. I idled it and I couldn't hear or feel any leaks.
Im at a lose of what to do at this point.
Old 06-03-2008, 07:11 PM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
It's not under load when you are idling. Only other thing you can do is have someone rev it a little..but it still wont be under load.
Almost sounds like you have a turbo..lol
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 06-03-2008, 07:12 PM   #10 (permalink)
EverReady's Avatar
Yeah I kind though it was cool then I though its probably destroying the life of my car and MPG and HP
