Quick Question, Oil plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2008, 06:55 PM   #1 (permalink)
View Kingdom934's Photo Gallery
Hey folks,
I have a quick question. I've did a few search regarding my question, but couldn't find anything solid.
I'm planning to do an oil change on my friend's Camry '97 LE V6. I'm wondering if the oil drain plug has a fiber/rubber gasket? I've been more familar with the older '85 Camry and the '87 Cressida that requires the black fiber/rubber gasket otherwise you'll end up leaking oil from the oil drain plug, but I don't know anything about the Gen4 regarding if they need an oil drain plug gasket.
Thanks,
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 06-03-2008, 06:57 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
dont believe it does. ive never noticed one on mine.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-03-2008, 06:57 PM   #3 (permalink)
Strum's Avatar
View Strum's Photo Gallery
Originally Posted by Kingdom934 View Post
Hey folks,
Thanks,
Quick answer - mine has a black rubber ring/gasket. I use the same one, never replaced it.
Mark
1993 Camry 6 cyl. (142K),
1998 Camry 4 cyl. (140K)
1996 Corolla (227K), 1997 Corolla (167K),
Strum is offline   Reply With Quote
Old 06-03-2008, 07:25 PM   #4 (permalink)
Hmmm...
Bigbird, yours is a '97 V6. Strum, yours would be the '98 I4? (I assume the one your talking about is a Gen4 since you also got another Gen3 Camry)
Interesting.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 06-03-2008, 07:37 PM   #5 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
I always use the crush washers that they use at the dealership when I change the oil on my Gen3.5 Camrys, both I4 and V6 and my Sequoia. I assume you should use them on Gen4 Camrys as well.
eddie926 is offline   Reply With Quote
Old 06-04-2008, 01:07 AM   #6 (permalink)
Thanks,
Well I went to the dealer and found they had gaskets. The gasket for the '97 Camry ran $1.89.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 06-04-2008, 09:26 AM   #7 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I replaced mine with an aluminum washer.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-04-2008, 10:01 AM   #8 (permalink)
Dino Turd Samurai
Copralite's Avatar
View Copralite's Photo Gallery
This is one of the better reasons to not get your oil changed at a cheapo place. Frequently they will not replace the gasket or washer, and they won't keep the one you have. So you end up with oil spots on your driveway.
Copralite is offline   Reply With Quote
Old 06-04-2008, 11:46 AM   #9 (permalink)
Strum's Avatar
Hmmm...
Interesting.
Yes, I'm referring to the Gen4. I don't recall what the Gen3 has, but I vaguely remember there not being any ring - whether by design or just missing, I'm not sure.
Mark
Old 06-05-2008, 05:24 PM   #10 (permalink)
Thanks guys.
I ended up changing my friend's 1MZ. When I tried taking the plug off, it move on the first turn, with very minimal force. Not even tighten on good! (He was leaking oil after a shop did the oil change). Took it off and no washer/gasket. No wonder it was dripping.
Also a mental note: don't jug the oil too fast down the 1MZ, it doesn't go in fast...
Yep.
I'm suprised they didn't have any washer. My mom does to the same place where my friend when as she didn't have any problem. Maybe because she goes early where the people are fresh when my friend went near closing, so they were all dead and tired.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 06-06-2008, 09:11 AM   #11 (permalink)
Heat's Avatar
View Heat's Photo Gallery
...Also a mental note: don't jug the oil too fast down the 1MZ, it doesn't go in fast...
$1.89 for the crush washer is pretty high, the price for the crush washers for my Honda as well as the Volvo I used to have was 50 cents or less. The next time you are at the dealer, ask how much a bag of the crush washers will cost - that should reduce your price per washer to less than a buck. If you want I can get you the part number tonight (the guy just gave me the bag so I don't know what the actual price was supposed to be). Or if you want to buy your oil filters online, check out www.toyotapartsales.com , $3.90 per filter plus shipping - you could get the crush washers at the same time at a discount (probably 20% to 25%).
As far as putting the new oil in, what I do is to cut a two liter soda bottle in half, rinse it out and dry it with a paper towel. That is then my oil funnel and I've never spilled oil out of it, nor does the oil go in too quick. When I'm done putting oil into the car, I then use the funnel to put the used oil into whatever container I'm using (milk jugs, old oil containers, etc), then I just throw the funnel away.
Heat is offline   Reply With Quote
Old 06-06-2008, 10:26 AM   #12 (permalink)
Darkside Cut Me!!!
Any auto parts store will have the crush washers, I got tired of throwing away the fiber washers, and picked up aluminum one which is reusable several times, Nylon and copper are also available.
2004 RX330 Sport
2003 Cam I4 XLE
Old 06-06-2008, 11:37 AM   #13 (permalink)
I'll try see what I can find. I know checkers here has washers on their store level, but not the ones I need. I'll see if they have some behind their counter
Yea. $1.89 is a bit high, then again we are located in the middle of the pacific ocean and with with gas prices rising...argh
I might just buy a bag later on. Depends if I make his oil change a common occurance.
As for the funnel, I had a fluid funnel. It would fit, but there's that flat spot in the engine near the oil cap, so it's like a 4 lane highway converted to a 2 lane highway. Reminds me of my Uncle's 1ZZ-FE. I just need to grab a smaller funnel so I don't go all happy go lucky with trying to jug all the oil down too fast.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
