1995 AC problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2008, 05:46 PM   #1 (permalink)
View Folken's Photo Gallery
Canada 1995 AC problem
Hey,
my 1995 AC has been working about 1/2 as good as it should for two years now. Can't be a leak or it would be gone right?
So I was thinking of recharging it with some with some coolant.
I think it takes 134A- can someone confirm that please?
Also, if anyone has instructions on topping up the AC collant for my 1995, please pass it along.
..............................Thanks Folken 1995LE & 2005 SE.............
Folken is offline   Reply With Quote
Old 06-04-2008, 09:43 PM   #2 (permalink)
View toyomoho's Photo Gallery
R-134A, yes.
Find the A/C receiver/dryer, there should be a sight glass on top of the unit allowing you to see the Freon inside the system. Look for air bubbles when the compressor is running if low on Freon.
A TN search of past posts should turn up info on recharging the system.
Old 06-05-2008, 01:39 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Also verify that the radiator is clean and the AC fan comes on when it should. My drier was under the battery.
Kep
Old 06-05-2008, 02:12 PM   #4 (permalink)
Thanks, but I cannot seem to find the link for recharging 1995 Camry....probably my bad.. so if anyone can provide it, much appreciated.............Folken
