Gen 3 AC Control lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2008, 09:41 AM   #1 (permalink)
View NoVaGator's Photo Gallery
3rd Generation Gen 3 AC Control lights
Hi All-
I've searched for this, but I couldn't find an answer for Gen3 (gen4, yes)
Replacing the lights behind the AC controls...
I've removed the lower trim around the storage bin and radio, popped off the knobs and slider, and removed the one screw under the left knob.
What else? Do I need to remove the entire black trim around the gauges? It looks like the trim that has the AC control markings on it is actually behind this big piece.
Halp!
NoVaGator is offline   Reply With Quote
Old 06-05-2008, 05:11 PM   #2 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
If your car is anything like mine, it will be difficult to replace. My HVAC is a bit different. I have knobs for the temp, fan speed, but the vent directing is all controlled electronically by buttons. If you need to remove this unit, you will need to take out your tape/cd deck since the wire that connects in the rear is hard to get to if you do not remove that!
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 06-05-2008, 06:07 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Not true. I have the XLE with the dial and push buttons. It's not at all hard to remove. After you remove the bottom panel that goes around the bottom of the radio, you need to remove the black trim piece that goes around the HVAC controls and instrument cluster. There are 2 screws in front of the instrument cluster up top and 2 screws below the HVAC controls, 1 on each side. Pull the black piece out and of the way. Then remove the 4 bolts that hold the HVAC controls on and remove the screw in the middle of the temperature control knob. Then pull the controls out and disconnect the wires on the back. You will see the bulbs on the backside of the HVAC controls.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 06-05-2008, 11:49 PM   #4 (permalink)
cruisn76's Avatar
^ i'll have to check it again. I couldn't find a way to remove that. Did you unplug the whole unit and removed it or did you just the 2 screws on the left and right???
Old 06-06-2008, 10:27 AM   #5 (permalink)
What exactly are you talking about cruisn? The HVAC control unit or the black dash surround?
Old 06-07-2008, 12:51 AM   #6 (permalink)
cruisn76's Avatar
^ The HVAC control unit. I had trouble getting the entire unit out from the dash. I couldn't unplug it to remove it completely.
Old 06-07-2008, 07:38 AM   #7 (permalink)
hmm...strange. There are 4 screws holding it in and 1 screw in the middle of the temperature control knob. Then you just pull it away from the dash slightly and disconnect the 3 plugs on the back.
Old 06-07-2008, 08:13 AM   #8 (permalink)
thanks for the info guys
I've ordered the replacement bulbs and I'll let you know how it goes
