Odd oil leak from cam breather - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2008, 04:03 PM   #1 (permalink)
View 96Toyo_Gracia's Photo Gallery
I have a 96 Toyo Camry (1mz motor) and the other day I happened to be under the hood looking at something and I noticed something odd. the intake we had on the car is somewhat of a make shift intake from a couple old pipes and couplings we had laying around. Theres no hole for the breather line coming from the top of my valve cover so to protect anything from getting in there I put one of those tiny little breather filters on the end of the hose and now I noticed the little filter is covered in this grimy dirt that I believe to be oil and dirt. obviously its been leaking for a while to accumulate dirt like that.
I was wondering if any one has had this happen to them or any ideas or what the problem (if any) is.
Thanks in advance,
Robbie
96Toyo_Gracia is offline   Reply With Quote
Old 06-06-2008, 12:25 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
if it's not excessive, then it's normal...oil fumes in the breather will also make dirt/grime stick
HaHa
Old 06-06-2008, 12:37 AM   #3 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426253
View EEngineer's Photo Gallery
i have the breather hole plugged....
is it better to plugg it or have it connect to a vacuum valve
or like he did put a tiny filter on it
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 06-06-2008, 12:55 AM   #4 (permalink)
View TMetalMan's Photo Gallery
I am not an expert, but I would assume there's pressure behind it since gases normally exit through there, so my thinking tells me it should be able to breathe freely. Normally these gases are recirculated through the intake pipe. Just today I actually removed my breather filter and reattached the hose from the outlet to the intake.
TMetalMan is offline   Reply With Quote
Old 06-06-2008, 01:16 AM   #5 (permalink)
TN Pussy Man
unplug it...it is there to vent gas....similar to the pcv....if you don't let the pressure out, then chances are that you'll blow seals
HaHa
Old 06-06-2008, 01:46 AM   #6 (permalink)
Born to Drive
EEngineer's Avatar
unplug it and plug it to where though?
or should i put a small filter there
Rest in Peace
Old 06-06-2008, 02:23 AM   #7 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
normally back to the intake manifold.
cykaaro is offline   Reply With Quote
Old 06-06-2008, 12:14 PM   #8 (permalink)
TN Pussy Man
yup yup...either a small breather (which works, but can dirty up your engine bay with tis fumes, which grim sticks to) or drill a hole in your intake pipe and jbweld on a fitting so that you can run your hose to it
HaHa
