^ What does the trim piece have to do with his A/C not working?
1. Check to see if you knocked the plug off the HVAC unit. Sometimes when you push the entire deck into the slot you drag a bit of wiring with it. So some might get tugged along like ur HVAC plug.
2. Check the speaker for rips, maybe, just maybe when you installed it you might have teared something around the rim of the speaker. Also make sure all the bolts are secure and the plug behind the speaker is not touching anything.
Also check your deck settings. Sometimes the settings are off.
good luck!
EDIT #2
2. Check the panel that you removed above the rear seats. That thing can rattle from time to time. Also check the grille cover above the speaker. I am not sure if you can remove it or not, but if you can, remove it!
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
