The door is that same and should fit no problem, but the door moulding is a different type between '98 and '01.
On the '98, the moulding is attached next to the horizontal channel that runs across the door. On the '01, the moulding attached into that channel and is wider.
If the moulding from the '01 can be reused, then you can use a heat gun to help remove the door moulding and attach to the '98 door (or course, you would need to remove the moulding on the '98 as well).
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
