Hello all.
I have a 94 Camry LE 2.2L. The check engine light is on and through some web surfing I was able to figure out how to retrieve the code for the problem. I was looking through your forum and came across a post from 2006. The solution provided by toyomoho below is, I believe, what I am looking for, I think. However, I have a few questions about the possible solution.
1st ? / What do all the accronyms mean?
ECU?
NE signal?
G signal?
DTC?
TDC?
2nd ? / The author, toyomoho, goes on to discuss checking resistance, I.E. G to G, NE to G. Does anyone have a diagram of the terminal layout the author is mentioning?
Thanks in advance for all your help.
Originally Posted by
toyomoho
Code 12: G, NE Signal Circuit (No 1)
The code is set if the ECU does not receive a NE signal for 2 seconds. Or a G signal for 3 seconds with RPM between 600 and 4K.
The distributor has two signal rotors. One sends out a G signal representing the standard crank position. Assume this is No 1 cylinder DTC. The other rotor sends out a signal representing crank position. Assume this is each cylinders TDC. The inputs from both signals allow the ECU to control timing.
Might check the following resistance:
G to G-- = 140-180 ohm
NE to G-- = same as above
When looking at the front of the electrical plug for the distributor, with the plug lock down. The terminal layout is G and NE on top (left to right), G-- (in lower right corner of plug).
The air gap between rotor and pick up coils should be 0.008 inch (0.2mm).
Check for loose or disconnected wires between the distributor and ECU. Coil primary resistance 0.41-0.50 ohm cold, secondary 10.2-13.8 ohm cold. Ignition wire resistance should be 25K ohm per wire.
