While you're there, do the timing belt change. It's standard practice to change the water pump when doing the timing belt anyway, because the belt has to come off, so you might as well replace the belt with a new one, then you're assured that THAT's done for at least another 60,000 miles. (But they always last over 80,000 miles.)
Do your homework, know the procedure for aligning the timing of the gears, do it right, with the right tools,
because if you don't, your car won't run right if it runs at all.
AND, DO NOT CHEAP OUT ON ANY PARTS! Use top quality brand name replacement parts ONLY. A
rebuilt water pump is fine, but make sure it's rebuilt by a company that has a VERY good reputation and
an even better warranty.
But, the big thing I'm seeing is that water pumps rarely cause overheating problems. Your entire cooling
system needs to be looked at. Lower thermostat, upper thermostat, ANY leaks in the coolant system.
Watch your coolant level very carefully. In the coolant filler port, NOT in the coolant bottle. And be sure
you're running a proper antifreeze mix. If the coolant level is going down slowly, you HAVE a leak. You
must find it and take care of it.
Odds are that if you haven't changed your radiator yet, it's probably due. I changed mine a few years ago
and that cured problems I wasn't even sure I'd call problems.
CJ
CJ
