removing front parking light cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2008, 01:27 PM   #1 (permalink)
View tedmn's Photo Gallery
Have a Camry 1996, cannot figure out how to remove front parking light cover.
Did remove the screw, the cover is loose, but now what? The book says to "push forward"???? Seems that there is a clip of some sort holding on, but I'm afraid of breaking it.
Thanks
tedmn is offline   Reply With Quote
Old 06-07-2008, 02:29 PM   #2 (permalink)
Noob
View gladis's Photo Gallery
If you're talking about the corner light next to the headlight, just remove the screw and pull it out.
Note that the whole assembly comes out, not just the cover, and that be careful you don't pull TOO hard, since it's obviously attached to a wire that the bulb is connected to.
When I did mine to inspect the bulbs, one of the pulled right out, and the other seemed stuck, and I just jostled it about until it came loose.
1996 Toyota Camry LE 2.2 - 139xxx 162xxx
2000 Toyota Sienna XLE 3.0 - 82xxx 104xxx
08/08 08/11
gladis is offline   Reply With Quote
