98 2.2L: Which tranny fluid? DIY? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2003, 07:42 PM   #1 (permalink)
ak1
View ak1's Photo Gallery
I've searched, but couldn't find much relevant info.
I need to flush and refill the tranny fluid in my 98 4cyl.
1) What kind of ATF does Toyota use? Dexron III?
2) Cheapest place to get the AT filter kit?
3) DIY link?
Thanks in advanced.
-ak1
ak1 is offline   Reply With Quote
Old 11-17-2003, 10:35 AM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $698565
iTrader Score: 6 reviews
View EKam's Photo Gallery
1. If you read your owner's manual, it'll probably say it's Dexron II, but III is also backward compatible.
2. Don't know what filter kit you're asking for. For drain and refill is just simply that.
3. Get a Haynes manual.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 11-17-2003, 02:40 PM   #3 (permalink)
View kocho's Photo Gallery
Re: 98 2.2L: Which tranny fluid? DIY?
3) DIY link?
Thanks in advanced.
-ak1
I did a flush at home a few weeks ago. Check my post for instructions. I did not change any filters - did not want to bother with dropping the pan...
I'm not sure if you want to put synthetic fluid in your '98, especially if you have a lot of miles on it - some folks have experienced leaks on older cars when switching to synthetic. On mine, so far no issues, but again I've had drained and refilled with Mobil 1 Synthetic ATF twice before I did the flush at about 76K miles.
Check these two links:
http://www.toyotanation.com/showthre...ighlight=flush
http://www.camryman.org/forum/viewto...ighlight=flush
My previous post does not mention it, but when the tranny fluid was in the middle between the hot and cold mark after I refilled, it turned-out that the level was actually right on when the tranny warmed-up. So, when you refill, do not overfill, until you get a chance to measure when the tranny is warmed-up.
Last thing, replace your differential fluid as well, if you haven't. Mine was quite dirty the first time I did it at about 30-35K. The differential fluid is separate from the tranny fluid.
kocho is offline   Reply With Quote
Old 11-17-2003, 08:21 PM   #4 (permalink)
ak1
Awesome. Thanks so much for the useful info!!!
Unfortunately, I lost the manual and couldn't find the info. on google.
