fixing A/C - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2008, 09:25 AM   #1 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
4th Generation fixing A/C
SO i was talking to my friend who just got a new car (02 WRX, Such a nice car)
And he was talking about how he fixed his A/C.
He said he bought a gauge to check the pressure in the hoses.
I know there is a high pressure one, and a low pressure one.
I can only find the low pressure one.
I have a 98 camry
Also, anyone know where i can get this gauge? (i assume advanced auto parts.)
deezeejoey is offline   Reply With Quote
Old 06-09-2008, 11:53 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Yes, but most part stores in the US will carry an aerosol can with gauge on a hose... what is your AC malfunction?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-09-2008, 12:03 PM   #3 (permalink)
Newbie
deezeejoey's Avatar
Just seems like to me that it just doesn't work.
Turn it on.... doesn't get cold at all... just blowing hot air at my face.
And with the past 3 days it's be well over 90 i'm in need of some A/C.
Are there any other ways of testing your A/C?
I have a coupon for a $9.99 A/C inspection for midas, but they've tried to rip me off before.
Old 06-10-2008, 12:20 AM   #4 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Just got mine working today actually, so this is what they did. Hope it helps somewhat.
First they have to evacuate the system and test the pressure As well lubricant was put in. If it doesn't hold pressure, then there's a leak that has to be fixed before it can be recharged. If it's an R12 system [which I believe your's isn't] then a retrofit just be done. The issue with my retrofit, the low side valve was corroded so I had to replace that part. Taking it out my system still had oil running through it so it I'm thinking the valve caused it to leak the freon out.
Now, if the system holds pressure, you should be good. At this point it's best to put in a stopleak as a preventative measure to help insure that nothing is going to start leaking on you. Doesn't mean it won't, but betters the chances that it won't. Then it's just charging the system and viola! Cold AC.
If the system is set up the same as the gen3, then the high side you'll find in the drivers front corner, and the low side is in the passengers side against the fire wall.
Hopefully the same is for your case. If it is leaking, then they need to put in a dye to see where the leak is , and go from there.
Good luck!
cykaaro is offline   Reply With Quote
Old 06-10-2008, 01:28 AM   #5 (permalink)
View 95toyotacamry's Photo Gallery
Well i only had problems with my ac like 2 times, i went to the mechanic and they just told me it was missing some gas there, the second time a hose was leaking the gas. And yep if it turns on but no cold air comes out is probably the gas, oh and there is a button there you re supposed to press after the A/C is on so the cold air starts to come.
95toyotacamry is offline   Reply With Quote
Old 06-10-2008, 11:42 AM   #6 (permalink)
Strum's Avatar
View Strum's Photo Gallery
Just curious if you got your A/C fixed? I have issues with the A/C on one of my cars and I haven't takled it yet. With mine I get no sound or change in RPM's when the A/C is turned on and of source no cold air.
The reason I ask if you got it fixed, is I live in Aurora OH and know the suffering you went through over the weekend if it wasn't fixed. If you didn't fix it, at least you have some cooler temps now.
Mark
1993 Camry 6 cyl. (142K),
1998 Camry 4 cyl. (140K)
1996 Corolla (227K), 1997 Corolla (167K),
Strum is offline   Reply With Quote
Old 06-10-2008, 12:04 PM   #7 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
deezeejoey, get a check/recharge kit r134a at the autoparts store or walmart or something...
strum, check in the right kick panel the 10A A/C fuse and the A/C magnetic clutch relay...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 06-10-2008, 12:20 PM   #8 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Originally Posted by Strum View Post
...The reason I ask if you got it fixed, is I live in Aurora OH and know the suffering you went through over the weekend if it wasn't fixed. If you didn't fix it, at least you have some cooler temps now.
all I can say is........... HA! Ohio?!?! Come on! Try living in Louisiana! Not only HOT...but HUMID!!!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 06-10-2008, 12:30 PM   #9 (permalink)
PERPETUAL NOOB
View Eric Marshall's Photo Gallery
3rd Generation retrofit ac
Hey xtreme - I didn't have to have it pulled down .I just started charging and after a few seconds the compressor kicked in! Now it's overheating even w/air off unless I'm going at least 45 mph. The hydraulic fan always runs and I can stop it with my bare hand. Sorry if I'm butting in!
93 LE V6 NOOBINATOR 192k+
Eric Marshall is offline   Reply With Quote
Old 06-10-2008, 01:54 PM   #10 (permalink)
I'm a Mac
zoni's Avatar
great skiing in louisiana too...
Dave Zoni
Old 06-10-2008, 02:22 PM   #11 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
we actually have quite a bit of humidity up here in ohio and michigan... but OT
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 06-10-2008, 05:30 PM   #12 (permalink)
Strum's Avatar
xtreme - Well, I'm not going to claim we have Louisiana weather all the time, but we were matching Baton rouge this past weekend with temps around mid 90 and the humidity around 85 to 90. This part of Ohio is known for high humidity, but it's usually July when it hits and August when it peaks. Right now it's about 80 degrees and the humidity has dropped to 50%. This morning the humidity was at 90%.
zoni - thanks for the suggestion, but what is the "A/C magnetic clutch relay"
Mark
Old 06-11-2008, 03:12 AM   #13 (permalink)
I'm a Mac
zoni's Avatar
its a relay... in that passenger side kick panel... it probably wont be marked... i can help you out a little better tomorrow...
Dave Zoni
Old 06-11-2008, 05:36 PM   #14 (permalink)
Newbie
deezeejoey's Avatar
I tired this today....
I noticed that once the pressure in the hose got to 45PSI the A/C finally kicked on.
Then i turned the car off, and i could hear air leaking from one of the hoses.\
and sorry xtreme, it's gets really humid here too.
Old 06-11-2008, 08:26 PM   #15 (permalink)
Which hose is it that's leaking? Luckily....the a/c lines are all in parts, so no one piece is very long or hard to replace. Just make sure you replace the o-rings too.
