Steering Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2008, 08:25 AM   #1 (permalink)
View slarson86's Photo Gallery
3rd Generation Steering Issue
I have a 1996 Toyota Camry LE with 74,000 miles and just recently I noticed that my steering has been a little off. What I mean by off is that the steering is stiff, but only at different points. For example, when I turn the wheel the stiffness will happen every 10-20 degrees of the turn. I just recently had the left front wheel replaced and the driver side axle replaced to pass inspection and I began to notice the steering problems after that, but I don't want to necessarily say it began with those changes.
A few diagnostic things I checked:
Fluid is fine, no leaks on floor, when I jack up the car and the pressure is off the tires/suspension there is no difficulty in turning the wheel while the engine is on or off.
I checked around the web and I really haven't found any answers to what it could be.
Thanks,
Shane
slarson86 is offline   Reply With Quote
Old 06-10-2008, 08:33 AM   #2 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
I would suspect a power steering issue first. However, I think I would take the vehicle back to the garage that changed the axle and just have them give it a once over. Tell them what is happening. There is no need to remove the outer tie-rod from the spindle to pull the axle but they may have left the axle bolt loose, pinched a power steering line or something of that nature. Unlikely but makes sense to start there.
frenum49 is offline   Reply With Quote
Old 06-20-2008, 04:27 PM   #3 (permalink)
View Jesse93's Photo Gallery
In December last year I was having the same problem with mine. After changing the rack and the pump... and at my wits end with it, discovered the problem was a bad steering knuckle where it come out of the firewall and before the rack connection.
May not be your trouble but I know I wish I had someone tell me to check it out before
I did all of the other & more expensive work to it!!
Jesse93 is offline   Reply With Quote
