Air Bag Light is On - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2008, 11:04 PM   #1 (permalink)
torontotenor's Avatar
View torontotenor's Photo Gallery
Air Bag Light is On
Directly after one of my teenage kids had a little temper tantrum and slammed her fist down on the dashboard of my 98 Camry the airbag light came on and remains on. Maybe its a coincidence, but is there anything I can do to reset the light or should I take the car to a dealership for a diagnosis. I was hoping the light would go off, but no such luck. Any advice is greatly appreciated, thanks in advance.
torontotenor is offline   Reply With Quote
Old 06-11-2008, 12:13 AM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Do a search, you'll find instructions on how to retrieve the code manually. Report back with what you've got, see if someone can't point you in the right direction.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 06-11-2008, 01:41 AM   #3 (permalink)
Don Julio
View future_spiegel's Photo Gallery
pull a russian and take out the dash and the light in the dash.
fixed!
future_spiegel is offline   Reply With Quote
Old 06-11-2008, 01:42 AM   #4 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Thanks. Searched and found how I should be able to clean my airbag light I kinda tripped. WOOWHO!
cykaaro is offline   Reply With Quote
Old 06-11-2008, 09:39 PM   #5 (permalink)
xtremeskier97's Avatar
Gameroom cash: $198580
View xtremeskier97's Photo Gallery
Yeah..its pretty simple. There is a port down by the drivers kick panel that is sort of round. That is where I did mine when I replaced my airbag. I have to do it again now since I had the whole dash out and had to remove the airbag/steering wheel.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 06-11-2008, 11:27 PM   #6 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
fixed!
gee....way to blow our cover
or just do what this russian is doing and drive around with it.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 06-11-2008, 11:32 PM   #7 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
Mine is on too. and i too drive a 98 camry.
just don't crash.
deezeejoey is offline   Reply With Quote
Old 06-12-2008, 02:43 AM   #8 (permalink)
Don Julio
i dont know how many cars i've done that on, lol!
sometimes i pull up to a nice beemer or benz and can tell its salvaged cuz the airbag light is on in the dash, lol!
you start getting a skill in this things...
Old 06-12-2008, 08:57 AM   #9 (permalink)
w00! I drive a Camry
View CamBOT's Photo Gallery
I reset it on my car, but i kept failing because i didn't understand the instructions properly.
So heres my version.
1. Hook up wires to Tc and Ab from the diag. ports either in the engine compartment or under the steering wheel column. (theres a sticker displaying the location of Tc and AB on the connector)
2. Connect a jumper cable directly to the battery and bring the other end into the car.
3. get in the car and close the door (for some reason it doesn't like open doors? maybe its me)
4. now connect the Tc wire to the jumper cable which is your ground
5. put your key in and turn it to ON position, wait about 6 seconds or until the chime stops
6. now remove the Tc wire from ground and ground AB
7. remove AB and ground Tc
8. remove Tc and ground AB
9. ground Tc and leave it there for about 20 seconds until the airbag light starts to flash rapidly
steps 6-9 must be done quickly and at an even pace
Thats it your're done. the flashing will stop when you disconnect your wires. Test that the code is cleared but taking the key out and starting the car. The airbag light should come on and go out after a while (normal operation)
I know this is a simple procedure, but i had trouble with it so i hope this helps. PM for questions
CamBOT
CamBOT is offline   Reply With Quote
