Hurting the tranny or no? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2008, 03:05 AM   #1 (permalink)
shajbot's Avatar
View shajbot's Photo Gallery
So I've been shifting it to N every time I have to do a hard brake because it seems to brake easier and less vibration and shift back to D when I need driving again. Is this healthy for the auto tranny? Only shifting to D when rpm about 1000 or so, I don't intend to rev and then shift though.
shajbot is offline   Reply With Quote
Old 06-11-2008, 05:20 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
shifting is what wares the tranny out. goin from D to N to D will ware on the tranny a little but if your only doin it under heavy braking then its really not gonna make any differance.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-11-2008, 07:12 AM   #3 (permalink)
View unkit's Photo Gallery
What about going from 4th to second to slow down?
unkit is offline   Reply With Quote
Old 06-11-2008, 01:34 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $127223
View Hajoca's Photo Gallery
Not a good practice to engine brake with your Trans. It will cause it to wear out. The transmission is not really made to back drive the engine.
Cars or trucks had used that option to offset over heating brakes when descending steep slopes.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
Old 06-11-2008, 01:51 PM   #5 (permalink)
View Bear95's Photo Gallery
I cut off my O/D when going down long hills here in the mountains to keep from overheating the brakes. This procedure is outlined in my OM.
Bear95
Bear95 is offline   Reply With Quote
Old 06-11-2008, 03:04 PM   #6 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
So you're saying you get less braking pulsation when your on neutral?
That might be a good indicative as to what the problem actually is.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 06-11-2008, 03:38 PM   #7 (permalink)
Darkside Cut Me!!!
Pulsation in pedal is worn suspension bushings, or warped rotors.
Long stretches of braking overheats the brake rotors.
Using O/D off puts transmission into 3rd, and not down to 2nd gear.
2004 RX330 Sport
2003 Cam I4 XLE
Old 06-11-2008, 08:07 PM   #8 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
get better pads that like heat!!! like my Hawk HPS, they love heat the hotter you get them the better they work!!!!!!! but when they are cold its not too fun!!!!
megamac83 is offline   Reply With Quote
Old 06-11-2008, 09:15 PM   #9 (permalink)
shajbot's Avatar
Yeah I kinda need stopping power when it's cold out too...
