timing belt help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2008, 07:50 PM   #1 (permalink)
Yeah, that's me
View Silent Shadow's Photo Gallery
3rd Generation timing belt help
i am working on replacing some stuff and need to get the crankshaft pulley off. any advice would be appreciated.
http://s307.photobucket.com/albums/n...t=DSC00157.jpg
http://s307.photobucket.com/albums/n...t=DSC00156.jpg
thanks
95 camry dx 2.2
Silent Shadow is offline   Reply With Quote
Old 06-11-2008, 09:15 PM   #2 (permalink)
Yeah, that's me
the problem is that it spins when you try to take the bolt off. not sure what to do. please help.
Old 06-11-2008, 10:01 PM   #3 (permalink)
View toyomoho's Photo Gallery
Find a couple of bolts that fit into the two holes on the pulley face. Bolt a section of wood to the pulley face, drill hole in wood for the socket. Make section length long enough that it binds up with the chassis or ground when the pulley rotates.
This issues has come up many times, a TN search should result in more ideas.
Old 06-11-2008, 11:21 PM   #4 (permalink)
Cannabis Camry's Avatar
View Cannabis Camry's Photo Gallery
Cant you jam the flywheel on these?
1998 Camry 2.2L 5SFE 5-Speed
Cannabis Camry is offline   Reply With Quote
Old 06-14-2008, 09:47 PM   #5 (permalink)
View ihgrad's Photo Gallery
I struggled for awhile, then found a very easy way to do this. Remove the flywheel access plate under the car (on the face of the transmission facing the oil pan- there is one mounting bracket you'll have to remove first- it's like 5 bolts total.). Get a long-tipped (flat-head) screwdriver. Slide the screwdriver between the flywheel teeth so the screwdriver is wedged against the tranny housing. Remember, the flywheel is going to want to spin counter-clockwise when removing the bolt (and vice-versa when reinstalling), so when removing, you'll be wedging it against the wall on the front side of the car. From my experience, it was a lot easier to loose the bolt pulling my breaker bar front out in front of the car. I just put the socket on the bolt with the bar hangin down, wrapped something around the bottom of the bar and pulled from out in front- got more leverage that way- popped loose in one try (of course I struggled for 3hrs inside the wheel well trying to loosen it). Good Luck!
ihgrad is offline   Reply With Quote
Old 06-14-2008, 09:56 PM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359160
iTrader Score: 13 reviews
^ yup, that's a great way. with the same concept, you can also take out the starter and jam a big screwdriver in the flywheel there too
and the easiest way is to put the socket/ratchet against the suspension arms and then use the starter to bump it off
HaHa
Old 06-15-2008, 10:02 PM   #7 (permalink)
Yeah, that's me
i tried whole putting it against the suspension and using the starter, and it wont work for some reason. i have already broken 2 adapters for the wrench. it just snaps right off, and the socket stays on.
flywheel thing tomorrow...
Old 06-15-2008, 10:28 PM   #8 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
How about using a impact wrench? Might work,
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 06-15-2008, 10:59 PM   #9 (permalink)
i go both ways-mac and PC
ghettosled's Avatar
Gameroom cash: $128595
whoa, you broke an adapter? that bolt is on there good. im assuming you are using a 3/8" drive with a 1/2" socket? i would invest in a 1/2" breaker bar. im not too surprised you are breaking adapters.
Old 06-16-2008, 06:05 PM   #10 (permalink)
Yeah, that's me
its a 1/2 wrench with a 3/8 socket.
and i broke 2 adapters
Old 06-16-2008, 06:14 PM   #11 (permalink)
Mr.Nutcase's Avatar
You need 1/2 socket, They are stonger than the 3/8 drive. Also spray something like PB Blaster
Old 06-19-2008, 01:40 AM   #12 (permalink)
View 4af89's Photo Gallery
3rd Generation
I just removed that bolt on my 93 V6 last week by using starter to crank it out. Man, I'm tried using 1/2 drive break bar. No luck. That bolt must be at least 150-200 lbs feet. Top little sh..
4af89 is offline   Reply With Quote
Old 06-19-2008, 02:18 AM   #13 (permalink)
Yeah, that's me
yeah. guess i need to get a new socket.
also, how do i get to the flywheel? and can I without removing the engine?
Old 06-19-2008, 09:46 PM   #14 (permalink)
Flywheel access plate under the car where the engine mates up with the transmission, right next to the oil pan. I find this easier than having to yank the starter....
