Just bought a 93 Camry/ New to the forum.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2008, 12:10 AM   #1 (permalink)
View eyecon7's Photo Gallery
Yea i just bought a 1993 Camry i think DX for 600 bucks 5spd... it runs good no problems at all and the body is in Great Shape.. i have a Few questions..
1) will the 96 Trunk fit on the 93 and what i need to make it fit
2) i want to lower the car... whats the lowest on springs? does any one have pictures
3) i looked for tokico Struts but it says its only for the 94 ??? does anyone have these....
4) i want to put 07 camry SE wheels. Will they Fit...
eyecon7 is offline   Reply With Quote
Old 06-12-2008, 03:40 AM   #2 (permalink)
No longer in use
View lgcongbach's Photo Gallery
1) 96 and 93 trunks are the same, they just look different because of the panel => direct swap.
2) 1-2 inches between fender and the tire should be enough.
3) 92-93-94 all in same generation, again direct swap.
4) gen 6 camry use 18' wheels, i've seen some members with 18' rim on their gen 3. That also should be a direct swap.
Disclaimer: I'm noob, so u better wait for some other comments ...
lgcongbach is offline   Reply With Quote
Old 06-12-2008, 03:51 AM   #3 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
2007 Camry Gen6 SE uses 17 inch wheels, not 18.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 06-12-2008, 04:53 AM   #4 (permalink)
Moderator
eyeball96's Avatar
Gameroom cash: $797377
iTrader Score: 59 reviews
What do u want to change the Trunk to a 96? If its for the center panel, it fits a 93.
eyeball96 is offline   Reply With Quote
Old 06-12-2008, 05:39 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
1) the 96 trunk will fit fine on the 93
2) lowest is coilovers, sprint springs are second with about a 2 " drop but they arent very good springs..they MUST have stiff shocks paired with them.
Springs & Struts Guide
3) they will fit fine
4) they will fit depending on the offset.
welcome to TN
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-12-2008, 09:04 AM   #6 (permalink)
Thanks Guys.. I bought it as a beater.... but i want to make it presentable..lol.... also has
anyone changed there motor mounts. Mine are gone....
Old 06-12-2008, 09:10 AM   #7 (permalink)
also what are the major differences in the 95-96. cause i see more stuff available.. is there a reason y i cant use the 96 Struts..
Old 06-12-2008, 11:33 AM   #8 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
I believe you can use gen 3.5 struts, but the difference is that the gen 3 struts are serviceable and the gen 3.5 struts are non-serviceable. From my understanding it means that a gen 3 can use struts for a gen 3.5 but if you do you can't go back to gen 3 struts if you decide to replace them again (if I am wrong, correct me please).
As for the differences in parts, in the manual it notes that the gen 3.5 models have a bearing and upper spring seat while the gen 3 doesn't (for the 2 front struts). But maybe this link will help:
Gen3 Front & Rear Suspension OEM parts number!
But hopefully someone else can give a bit more info
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
Old 06-24-2008, 12:23 PM   #9 (permalink)
Bump I have another Question. I need to recharge My AC its a 93 V4 whats the Freon The R12 or 134a... And
which cap do i use to Charge the AC the Black or RED???
Old 06-24-2008, 08:54 PM   #10 (permalink)
xtremeskier97's Avatar
Gameroom cash: $198580
View xtremeskier97's Photo Gallery
Its a 94 I4 not V4...and the original freon will be posted on the underside of the hood. 93-94 was right around the time they were changing things over to R134a.
And to charge the system, you use the valve next to the firewall on the passenger side of the car.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
